braaak
January 11, 2022, 2:48pm
1
Any help for a newbie would be very appreciated - thank you!
I try making my first steps in HA using a vacuum communicating via MQTT. My intention is to do the following:
(1) Vaccum a room 2 times.
(2) Afterwards (!) mop it.
I made a script for (part 1) that finally calls up an automation (part 2) triggering to wait for the vacuum to return before beginning to mop.
Each, the script and the automation, work for itselves: but I am not able to call the automation from inside the script. And yes - as far as a newbie can - I read the HA informations about script- and automation-integration, but I suppose as someone with 0 programming experience there is a lack in my logic and this is not documented anywhere …
So if anyone could help my come a little bit closer to my goal - I would be very thankful!
Kay
(1) This is the script code:
alias: Badezimmer reinigen
sequence:
- service: mqtt.publish
topic: valetudo/robot/FanSpeedControlCapability/preset/set
payload: max
topic: valetudo/robot/WaterUsageControlCapability/preset/set
payload: off
topic: valetudo/robot/MapSegmentationCapability/clean/set
payload: '{"segment_ids": ["19"], "iterations": 2, "customOrder": true}'
- delay: '00:00:15'
- service: automation.badezimmer_wischen
mode: single
icon: mdi:bathtub
(2) And the automation:
alias: Badezimmer wischen
description: ''
- platform: mqtt
topic: valetudo/robot/StatusStateAttribute/status
payload: cleaning
encoding: utf-8
- wait_for_trigger:
- platform: mqtt
payload: docked
encoding: utf-8
payload: low
payload: high
you need to trigger the automation
service: automation.trigger
entity_id: automation.badezimmer_wischen
but why you are not just adding the steps into your script?
the autmation does not make sense for me
braaak
January 11, 2022, 2:58pm
3
Because HA does not accept the script code, when I insert something like “automation:”…
braaak
January 11, 2022, 3:12pm
4
… or is there any way to insert a trigger directly into a script?
you could do it with a condition instead of wait for trigger
braaak
January 11, 2022, 3:20pm
6
Okay, but I have not Idea how to implement the condition with kind of “wait for condition”? Or is a condition always a state that is waited for?
sorry, you are right. this will not work. it will not wait
but you can add a wait for trigger in the script
braaak
January 11, 2022, 3:32pm
9
Okay, I See… What do you think: like this?
alias: Badezimmer reinigen TEST
sequence:
payload: max
payload: 'off'
- delay: '00:00:15'
- alias: "Wait for Vacuum to return and being docked"
wait_for_trigger:
- platform: mqtt
payload: docked
encoding: utf-8
payload: low
payload: high
mode: single
icon: mdi:bathtub
braaak
January 11, 2022, 3:44pm
10
Just tried it: Does not work
(While “Script =calls=> automation” works!!)
Any idea how to make this more elegant second method (without automation-detour) work?
braaak
January 11, 2022, 3:49pm
11
YIPEEEE - WORKS like this:
sequence:
payload: max
payload: 'off'
- delay: '00:00:15'
- wait_for_trigger:
- platform: mqtt
payload: returning
encoding: utf-8
payload: low
payload: high
mode: single
icon: mdi:bathtub
Deleted the “alias”-part and perfect!!!
Thank you very much!!
