I upgraded to 38.2 yesterday but now when I try to start HASS, it gets stuck here:
INFO:homeassistant.util.package:Attempting install of sqlalchemy==1.1.5
I let it sit there for hours. I uninstalled home assistant and reinstalled with the same results. I also tried downgrading back to the previous version and no luck.
You could try installing it manually and see if it generates a meaningful error. Just make sure that if you installed to a virtual environment that you do your install there.
No, that looks correct. Try updating pip3 first and see if it just needs a reference to the lib updated. I believe the command is below, but you may want to double check.
I added verbose to the sqlalchemy command and got this:
>pip3 -v install sqlalchemy==1.1.5
Config variable 'Py_DEBUG' is unset, Python ABI tag may be incorrect
Config variable 'WITH_PYMALLOC' is unset, Python ABI tag may be incorrect
Collecting sqlalchemy==1.1.5
1 location(s) to search for versions of sqlalchemy:
* https://pypi.python.org/simple/sqlalchemy/
Getting page https://pypi.python.org/simple/sqlalchemy/
Looking up "https://pypi.python.org/simple/sqlalchemy/" in the cache
No cache entry available
Starting new HTTPS connection (1): pypi.python.org
"GET /simple/sqlalchemy/ HTTP/1.1" 200 10174
Updating cache with response from "https://pypi.python.org/simple/sqlalchemy/"
Caching b/c date exists and max-age > 0
When I hit ctrl+c to stop the above command, it dumped out some more information, including a line about some lock file. I found the lock file and deleted it manually. This fixed the sqlalchemy problem but then I got stuck at another one. I just deleted the entire python cache directory and everything is working now. Thanks for your help!
Great news! When you go to the web UI, I’d suggest doing a full cache and history clean on your browser. A LOT of frontend changes were made and things will may look weird and not display correctly - this will fix it.
I’m experiencing this issue also and I fail to see how clearing my browser’s cache is going to fix an issue I’m having with installing sqlalchemy dependency?
