I’m trying to install HA on a RPI 3 B+ and instead of using the pre-built image (because I want to be able to use the add-ons) I used Etcher to burn Raspian Stretch Lite and after that booted up did the following
sudo su
curl -sL https://raw.githubusercontent.com/dale3h/hassio-installer/master/hassio_rpi3bp | bash -s
It’s been a couple of hours and I’m still stuck at the “preparing hass.io” screen. What am I doing wrong?
There is a HassOS you could try instead of the hack to run Hassio? It’s stable now and is the same as Hassio except it is not based on ResinOS. HassOS is the future.
