Is there any proper solution for this? I have a device that dropped off my network, I tried to reset it and “add devices” there were issues… ever since then I get the dreaded “starting z-wave network” message…
I did delete the database, didn’t help. I added the lines:
zwave:
usb_path: /dev/serial/by-id/usb-0658_0200-if00
to configuration.yaml… the zwave logs show that stuff is happening…
2021-10-07 10:43:27.123 Detail,
2021-10-07 10:43:27.124 Info, Node009, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2021-10-07 10:43:27.125 Detail, Node009, Refreshed Value: old value=0, new value=0, type=byte
2021-10-07 10:43:27.125 Detail, Node009, Changes to this value are not verified
2021-10-07 10:43:27.126 Detail, Node009, Refreshed Value: old value=0, new value=0, type=byte
2021-10-07 10:43:27.126 Detail, Node009, Changes to this value are not verified
2021-10-07 10:43:27.127 Detail, Node009, Refreshed Value: old value=0, new value=0, type=byte
2021-10-07 10:43:27.127 Detail, Node009, Changes to this value are not verified
2021-10-07 10:43:27.127 Detail, Node009, Refreshed Value: old value=8, new value=8, type=byte
2021-10-07 10:43:27.128 Detail, Node009, Changes to this value are not verified
2021-10-07 10:43:27.128 Detail, Node009, Notification: ValueChanged
2021-10-07 10:43:27.132 Detail, Node009, Notification: ValueChanged
2021-10-07 10:43:27.137 Detail, Node009, Notification: ValueChanged
2021-10-07 10:43:27.142 Detail, Node009, Notification: ValueChanged
2021-10-07 10:44:36.138 Detail, Node009, Received: 0x01, 0x11, 0x00, 0x04, 0x00, 0x09, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x08, 0x00, 0xd5, 0x00, 0xbb
2021-10-07 10:44:36.140 Info, Node009, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2021-10-07 10:44:36.141 Detail, Node009, Refreshed Value: old value=0, new value=0, type=byte
2021-10-07 10:44:36.141 Detail, Node009, Changes to this value are not verified
2021-10-07 10:44:36.142 Detail, Node009, Refreshed Value: old value=0, new value=0, type=byte
2021-10-07 10:44:36.143 Detail, Node009, Changes to this value are not verified
2021-10-07 10:44:36.144 Detail, Node009, Refreshed Value: old value=0, new value=0, type=byte
but no such luck in the GUI.
