Hi there. I have build a simple script for controlling my Mertik Maxitrol GV60 controller for fireplace. I have studied the fireplace manual for a long time and was able to find out which circuit must be closed for certain functionality for the wall switch connection. I connected a 4-way relay to it with an ESP32. It’s working fine but I would like to refine my script to a more ‘professional’ version with some additional checks. I read alot on the esphome but it’s beyond my programming knowledge.
What I just can’t manage is the following:
I would like have a status sensor with an entry of the last chosen platform name turn_on_action
This way I can read the current status of the fireplace in Home Assistant. -
Because the relay’s needed to be inverted (otherwise they are all on by default) the status does not want to change to on. I use lambda for this where I look at the status of 1 switch ID. But the way I’ve done it now, the lambda IF states are not unique. I would like to make an IF statement where at least 2 id’s must match before a true can be given.
It’s my first code in esphome so if you guys can help me? That would be fantastic
esphome:
platform: ESP32
board: nodemcu-32s
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Openhaard Fallback Hotspot"
password: "notworking"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
switch:
- platform: gpio
pin: GPIO16
internal: yes
inverted: yes
restore_mode: ALWAYS_OFF
- platform: gpio
pin: GPIO17
internal: yes
inverted: yes
- platform: gpio
pin: GPIO18
internal: yes
inverted: yes
- platform: gpio
pin: GPIO19
internal: yes
inverted: yes
icon: "mdi:fire"
lambda: |-
if (id(pin0).state) {
return true;
} else {
return false;
turn_on_action:
- switch.turn_on: pin0
- switch.turn_on: pin1
- switch.turn_on: pin3
- delay: 4s
- switch.turn_off: pin0
- switch.turn_off: pin1
- switch.turn_off: pin3
icon: "mdi:inbox-arrow-up"
lambda: |-
if (id(pin1).state) {
return true;
} else {
return false;
turn_on_action:
turn_off_action:
icon: "mdi:inbox-arrow-down"
lambda: |-
if (id(pin3).state) {
return true;
} else {
return false;
turn_on_action:
turn_off_action:
icon: "mdi:infinity"
lambda: |-
return true;
} else {
return false;
turn_on_action:
- delay: 12s
name: "Uit (Wintertijd)"
icon: "mdi:radiator-off"
lambda: |-
if (id(pin2).state) {
return true;
} else {
return false;
turn_on_action:
- switch.turn_on: pin2
- delay: 1s
- switch.turn_off: pin2
