Replace the Interrutor entity with your entity whithin the each blue node (three nodes total). I believe this is the behaviour you were expecting?
[{"id":"6b773c7df5fc80fc","type":"trigger-state","z":"878e74c2.7f39c8","name":"Interruptor no manual","server":"9405c3fe.d0a6c","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"Interruptor","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"inputs":1,"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","enableInput":true,"x":340,"y":220,"wires":[["c510a063594c7905"],[]]},{"id":"d56e54b9256cabfd","type":"change","z":"878e74c2.7f39c8","name":"enable","rules":[{"t":"set","p":"payload","pt":"msg","to":"enable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":150,"y":200,"wires":[["6b773c7df5fc80fc"]]},{"id":"bddfeafcf1e46bdb","type":"change","z":"878e74c2.7f39c8","name":"dis","rules":[{"t":"set","p":"payload","pt":"msg","to":"disable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":150,"y":240,"wires":[["6b773c7df5fc80fc"]]},{"id":"c510a063594c7905","type":"change","z":"878e74c2.7f39c8","name":"almacenar estado interruptor","rules":[{"t":"set","p":"interruptorRecovery","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":160,"wires":[["9998f5e145905952"]]},{"id":"932a9bd24c7cd88d","type":"link in","z":"878e74c2.7f39c8","name":"link in 8","links":["84e3d12bb1b77be0"],"x":65,"y":200,"wires":[["d56e54b9256cabfd"]]},{"id":"ba3b76da609769a3","type":"link in","z":"878e74c2.7f39c8","name":"link in 9","links":["6c86fd4a87e19122","9998f5e145905952"],"x":65,"y":240,"wires":[["bddfeafcf1e46bdb"]]},{"id":"9998f5e145905952","type":"link out","z":"878e74c2.7f39c8","name":"link out 39","mode":"link","links":["ba3b76da609769a3","1b173490589085fc","3d8cc6d15ad3ec3e"],"x":755,"y":160,"wires":[]},{"id":"1b173490589085fc","type":"link in","z":"878e74c2.7f39c8","name":"link in 10","links":["9998f5e145905952"],"x":825,"y":160,"wires":[["0e1800bd78b45e34"]]},{"id":"0e1800bd78b45e34","type":"trigger","z":"878e74c2.7f39c8","name":"bloqueo de 10s","op1":"","op2":"1","op1type":"nul","op2type":"str","duration":"10","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":940,"y":160,"wires":[["84e3d12bb1b77be0"]]},{"id":"84e3d12bb1b77be0","type":"link out","z":"878e74c2.7f39c8","name":"link out 40","mode":"link","links":["932a9bd24c7cd88d","c711148e7c5ee87f"],"x":1055,"y":160,"wires":[]},{"id":"9cb91ca41167dc99","type":"trigger-state","z":"878e74c2.7f39c8","name":"Interruptor cambio manual","server":"9405c3fe.d0a6c","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"Interruptor","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is_not","comparatorValueDatatype":"jsonata","comparatorValue":"$flowContext(\"interruptorRecovery\")"}],"inputs":1,"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","enableInput":true,"x":350,"y":400,"wires":[["8f2ff7078206266d"],[]]},{"id":"81f57face2503cf7","type":"change","z":"878e74c2.7f39c8","name":"enable","rules":[{"t":"set","p":"payload","pt":"msg","to":"enable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":150,"y":380,"wires":[["9cb91ca41167dc99"]]},{"id":"c31b812bf5cb505f","type":"change","z":"878e74c2.7f39c8","name":"dis","rules":[{"t":"set","p":"payload","pt":"msg","to":"disable","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":150,"y":420,"wires":[["9cb91ca41167dc99"]]},{"id":"3d8cc6d15ad3ec3e","type":"link in","z":"878e74c2.7f39c8","name":"link in 11","links":["9998f5e145905952"],"x":65,"y":380,"wires":[["81f57face2503cf7"]]},{"id":"c711148e7c5ee87f","type":"link in","z":"878e74c2.7f39c8","name":"link in 12","links":["84e3d12bb1b77be0"],"x":65,"y":420,"wires":[["c31b812bf5cb505f"]]},{"id":"8f2ff7078206266d","type":"api-call-service","z":"878e74c2.7f39c8","name":"Recover state","server":"9405c3fe.d0a6c","version":5,"debugenabled":false,"domain":"switch","service":"turn_{{flow.interruptorRecovery}}","areaId":[],"deviceId":[],"entityId":["Interruptor#"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":580,"y":400,"wires":[[]]},{"id":"9d0e0d3b28b841e8","type":"comment","z":"878e74c2.7f39c8","name":"Cambio NO manual","info":"","x":150,"y":100,"wires":[]},{"id":"5d1aec98df49821f","type":"comment","z":"878e74c2.7f39c8","name":"Cambio manual durante los primeros 10s","info":"","x":220,"y":300,"wires":[]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
