Stuck in Kiosk mode
I was trying to test out kiosk mode in CCH and forgot to set exclusions for certain users. Now every time I log in to goes straight to kiosk mode. I uninstalled and reinstalled the CCH component through the HA android app but it still reverts to kiosk mode.
Try this.
You can disable CCH by adding “?disable_cch” to the end of your URL.
I tried that and it doesn’t seem to work. http://ip:8123?disable_cch
That’s what I tried and no luck
Try
https://192.168.1.209:8123/lovelace/0?disable_cch
That did the trick! Thanks
I have made the same error with kiosk mode
Using actually the last version 107 when I try to enter Home assistant with this command
“192.18.1.21:8123/lovelace/0?disable” I get, after login and password 1 sec the normal screen and then it goes back to the kiosk mode
Is there another way to recovery from this situation ?
Thanks in advance for your attentio nand replay
Patou
I know this question was asked a long time ago, but I made the same mistake and figured out how to fix it.
Login with this url and you will go directly to edit screen
http://homeassistant.local:8123/lovelace/0?edit=1
Then you can edit the dashboard and fix it!
Does this only work when logged in locally???
First post :slight_smile:
Big thx to this wonderful community :world_map: Helped me going through my first Home Assistant experience ever, just like a litte boy learning walking, learning things :rocket: :star:
I managed to exit kiosk mode here with :
<your.homeassistant.url>?disable_km
