I’m on HA 0.112.4. Supervisor gives me no indication of an available update to 0.112.5. However, when I run the Check Home Assistant configuration add-on, it temporarily installed 0.112.5 and tells me “Configuration check finished - no error found!”
For reference, I have Hassio installed on a Raspberry Pi 2.
I tried to force the update through ha core update —version=0.112.5 on the command line but that didn’t work.
What is the issue? And is there a way I can force the update?
