I just installed home assistant os on my raspberry pi 3 b. I tried creating a new account but the loading bar at the top keeps getting stuck at about a third. Any help?
Update: I rebooted and now it takes to the login page but my login doesnt work
I have had a similar issue with Home Assistant Green. The solution was to reflash and when you create a password, just use numbers and lowercase letters, no capitals.
Hope this helps
Martin
I ran into the same issue above and this method worked to get me setup. Thanks!
Thank you, that did the trick for me too.
