Stuck on Home Assistant 0.103.6
I am currently on version 0.103.6 but need to upgrade to install SpotCast. The update completes but stays on the same version. Any tips for upgrading to 0.108.6?
I am running HA in a venv so I stopped it and then ran the following
cd homeassistant
source bin/activate
python3 -m pip install --upgrade homeassistant
This is what I get, looks like it is saying it is already up to date:
Requirement already up-to-date: homeassistant in ./lib/python3.6/site-packages (0.103.6)
Requirement already satisfied, skipping upgrade: async-timeout==3.0.1 in ./lib/python3.6/site-packages (from homeassistant) (3.0.1)
Requirement already satisfied, skipping upgrade: certifi>=2019.9.11 in ./lib/python3.6/site-packages (from homeassistant) (2020.4.5.1)
Requirement already satisfied, skipping upgrade: PyJWT==1.7.1 in ./lib/python3.6/site-packages (from homeassistant) (1.7.1)
Requirement already satisfied, skipping upgrade: attrs==19.3.0 in ./lib/python3.6/site-packages (from homeassistant) (19.3.0)
Requirement already satisfied, skipping upgrade: python-slugify==4.0.0 in ./lib/python3.6/site-packages (from homeassistant) (4.0.0)
Requirement already satisfied, skipping upgrade: jinja2>=2.10.3 in ./lib/python3.6/site-packages (from homeassistant) (2.11.2)
Requirement already satisfied, skipping upgrade: importlib-metadata==0.23 in ./lib/python3.6/site-packages (from homeassistant) (0.23)
Requirement already satisfied, skipping upgrade: pip>=8.0.3 in ./lib/python3.6/site-packages (from homeassistant) (20.0.2)
Requirement already satisfied, skipping upgrade: requests==2.22.0 in ./lib/python3.6/site-packages (from homeassistant) (2.22.0)
Requirement already satisfied, skipping upgrade: voluptuous==0.11.7 in ./lib/python3.6/site-packages (from homeassistant) (0.11.7)
Requirement already satisfied, skipping upgrade: voluptuous-serialize==2.3.0 in ./lib/python3.6/site-packages (from homeassistant) (2.3.0)
Requirement already satisfied, skipping upgrade: cryptography==2.8 in ./lib/python3.6/site-packages (from homeassistant) (2.8)
Requirement already satisfied, skipping upgrade: bcrypt==3.1.7 in ./lib/python3.6/site-packages (from homeassistant) (3.1.7)
Requirement already satisfied, skipping upgrade: aiohttp==3.6.1 in ./lib/python3.6/site-packages (from homeassistant) (3.6.1)
Requirement already satisfied, skipping upgrade: astral==1.10.1 in ./lib/python3.6/site-packages (from homeassistant) (1.10.1)
Requirement already satisfied, skipping upgrade: contextvars==2.4; python_version < “3.7” in ./lib/python3.6/site-packages (from homeassistant) (2.4)
Requirement already satisfied, skipping upgrade: pyyaml==5.1.2 in ./lib/python3.6/site-packages (from homeassistant) (5.1.2)
Requirement already satisfied, skipping upgrade: pytz>=2019.03 in ./lib/python3.6/site-packages (from homeassistant) (2019.3)
Requirement already satisfied, skipping upgrade: ruamel.yaml==0.15.100 in ./lib/python3.6/site-packages (from homeassistant) (0.15.100)
Requirement already satisfied, skipping upgrade: text-unidecode>=1.3 in ./lib/python3.6/site-packages (from python-slugify==4.0.0->homeassistant) (1.3)
Requirement already satisfied, skipping upgrade: MarkupSafe>=0.23 in ./lib/python3.6/site-packages (from jinja2>=2.10.3->homeassistant) (1.1.1)
Requirement already satisfied, skipping upgrade: zipp>=0.5 in ./lib/python3.6/site-packages (from importlib-metadata==0.23->homeassistant) (3.1.0)
Requirement already satisfied, skipping upgrade: idna<2.9,>=2.5 in ./lib/python3.6/site-packages (from requests==2.22.0->homeassistant) (2.8)
Requirement already satisfied, skipping upgrade: chardet<3.1.0,>=3.0.2 in ./lib/python3.6/site-packages (from requests==2.22.0->homeassistant) (3.0.4)
Requirement already satisfied, skipping upgrade: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in ./lib/python3.6/site-packages (from requests==2.22.0->homeassistant) (1.25.9)
Requirement already satisfied, skipping upgrade: six>=1.4.1 in ./lib/python3.6/site-packages (from cryptography==2.8->homeassistant) (1.14.0)
Requirement already satisfied, skipping upgrade: cffi!=1.11.3,>=1.8 in ./lib/python3.6/site-packages (from cryptography==2.8->homeassistant) (1.14.0)
Requirement already satisfied, skipping upgrade: multidict<5.0,>=4.5 in ./lib/python3.6/site-packages (from aiohttp==3.6.1->homeassistant) (4.7.5)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in ./lib/python3.6/site-packages (from aiohttp==3.6.1->homeassistant) (1.4.2)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5; python_version < “3.7” in ./lib/python3.6/site-packages (from aiohttp==3.6.1->homeassistant) (3.7.4.2)
Requirement already satisfied, skipping upgrade: idna-ssl>=1.0; python_version < “3.7” in ./lib/python3.6/site-packages (from aiohttp==3.6.1->homeassistant) (1.1.0)
Requirement already satisfied, skipping upgrade: immutables>=0.9 in ./lib/python3.6/site-packages (from contextvars==2.4; python_version < “3.7”->homeassistant) (0.11)
Requirement already satisfied, skipping upgrade: pycparser in ./lib/python3.6/site-packages (from cffi!=1.11.3,>=1.8->cryptography==2.8->homeassistant) (2.20)
You missed this in the 0.103 release notes
Therefore, this release marks the last release, which supports Python 3.6.
If you haven’t upgraded your system to Python 3.7 yet, it is recommended to do so, to ensure you can keep using Home Assistant in the future.
You need to install Python 3.7 or 3.8 (I’d recommend 3.8) and build a new venv with that.
That did it! Thanks
