Hi, I’m taking my first steps in the world of home assistants. A few weeks ago I did the fork of the repository from another pc, following the guidelines provided here Set up Development Environment | Home Assistant Developer Docs to setup my development environment and everything went fine well, the home assistant instance starts and works perfectly. I changed pc, repeated the same steps, but now when I run home assistant from vs code I get stuck on " INFO (MainThread) [homeassistant.core] Starting Home Assistant".
On docker the container has started, and if I look at localhost:8123 it shows me the login page as well as for the old pc. I ran the pip list command to compare the installed dependencies and they seem to match. I checked the logs and apart from some warnings that also appear when starting the home assistant instance of the old pc, I don’t see any errors. Can anyone help me at least figure out what else to look for? I’ve been trying to fix it for days without success.
The logs:
2023-02-01 10:06:40.131 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds
2023-02-01 10:06:40.137 INFO (MainThread) [homeassistant.bootstrap] Setting up frontend: {‘frontend’}
2023-02-01 10:06:40.166 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2023-02-01 10:06:40.168 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds
2023-02-01 10:06:40.230 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2023-02-01 10:06:40.248 INFO (MainThread) [homeassistant.setup] Setting up http
2023-02-01 10:06:40.261 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds
2023-02-01 10:06:40.289 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds
2023-02-01 10:06:40.318 INFO (MainThread) [homeassistant.setup] Setting up api
2023-02-01 10:06:40.325 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds
2023-02-01 10:06:40.326 INFO (MainThread) [homeassistant.setup] Setting up auth
2023-02-01 10:06:40.331 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds
2023-02-01 10:06:40.334 INFO (MainThread) [homeassistant.setup] Setting up config
2023-02-01 10:06:40.348 INFO (MainThread) [homeassistant.setup] Setting up diagnostics
2023-02-01 10:06:40.358 INFO (MainThread) [homeassistant.setup] Setting up file_upload
2023-02-01 10:06:40.362 INFO (MainThread) [homeassistant.setup] Setup of domain file_upload took 0.0 seconds
2023-02-01 10:06:40.368 INFO (MainThread) [homeassistant.setup] Setting up repairs
2023-02-01 10:06:40.371 INFO (MainThread) [homeassistant.setup] Setup of domain repairs took 0.0 seconds
2023-02-01 10:06:40.372 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2023-02-01 10:06:40.378 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds
2023-02-01 10:06:40.539 WARNING (MainThread) [asyncio] Executing <Task finished name=‘Task-125’ coro=<async_setup..setup_panel() done, defined at /workspaces/freehandsIntegrations/homeassistant/components/config/init.py:42> result=None created at /usr/local/lib/python3.9/asyncio/tasks.py:361> took 0.141 seconds
2023-02-01 10:06:40.610 INFO (MainThread) [homeassistant.setup] Setting up image
2023-02-01 10:06:40.614 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.3 seconds
2023-02-01 10:06:40.618 INFO (MainThread) [homeassistant.setup] Setup of domain diagnostics took 0.3 seconds
2023-02-01 10:06:40.644 INFO (SyncWorker_0) [homeassistant.loader] Loaded group from homeassistant.components.group
2023-02-01 10:06:40.669 INFO (MainThread) [homeassistant.setup] Setup of domain image took 0.1 seconds
2023-02-01 10:06:40.688 INFO (SyncWorker_0) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
2023-02-01 10:06:40.708 INFO (MainThread) [homeassistant.setup] Setting up search
2023-02-01 10:06:40.709 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds
2023-02-01 10:06:41.643 INFO (MainThread) [homeassistant.setup] Setting up analytics
2023-02-01 10:06:41.656 WARNING (MainThread) [asyncio] Executing <Task pending name=‘Task-103’ coro=<_async_setup_component() running at /workspaces/freehandsIntegrations/homeassistant/setup.py:235> wait_for=<Task pending name=‘Task-209’ coro=<Store._async_load() running at /workspaces/freehandsIntegrations/homeassistant/helpers/storage.py:118> cb=[<TaskWakeupMethWrapper object at 0x7f6d269c1790>()] created at /workspaces/freehandsIntegrations/homeassistant/core.py:511> cb=[<TaskWakeupMethWrapper object at 0x7f6d34d3cd90>()] created at /workspaces/freehandsIntegrations/homeassistant/core.py:511> took 0.938 seconds
2023-02-01 10:06:41.667 INFO (MainThread) [homeassistant.setup] Setting up person
2023-02-01 10:06:41.672 INFO (MainThread) [homeassistant.setup] Setup of domain analytics took 0.0 seconds
2023-02-01 10:06:41.704 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.0 seconds
2023-02-01 10:06:41.718 INFO (SyncWorker_0) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio
2023-02-01 10:06:41.724 INFO (SyncWorker_1) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2023-02-01 10:06:41.743 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2023-02-01 10:06:41.754 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds
2023-02-01 10:06:41.761 INFO (MainThread) [homeassistant.setup] Setting up frontend
2023-02-01 10:06:41.772 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds
2023-02-01 10:06:41.785 INFO (MainThread) [homeassistant.bootstrap] Setting up recorder: {‘recorder’}
2023-02-01 10:06:41.794 INFO (MainThread) [homeassistant.setup] Setting up recorder
2023-02-01 10:06:41.813 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //workspaces/freehandsIntegrations/config/home-assistant_v2.db was shutdown cleanly
2023-02-01 10:06:41.910 INFO (MainThread) [asyncio] <Server sockets=(<asyncio.TransportSocket fd=12, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=(‘0.0.0.0’, 8123)>, <asyncio.TransportSocket fd=13, family=AddressFamily.AF_INET6, type=SocketKind.SOCK_STREAM, proto=6, laddr=(‘::’, 8123, 0, 0)>)> is serving
2023-02-01 10:06:41.911 INFO (MainThread) [homeassistant.components.http] Now listening on port 8123
2023-02-01 10:06:41.923 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.1 seconds
2023-02-01 10:06:41.930 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {‘ssdp’, ‘zeroconf’, ‘usb’, ‘http’, ‘websocket_api’, ‘network’, ‘api’, ‘cloud’, ‘dhcp’, ‘bluetooth’, ‘webhook’}
2023-02-01 10:06:41.961 INFO (MainThread) [homeassistant.setup] Setting up webhook
2023-02-01 10:06:41.964 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds
2023-02-01 10:06:41.992 INFO (MainThread) [homeassistant.setup] Setting up usb
2023-02-01 10:06:41.997 INFO (MainThread) [homeassistant.setup] Setup of domain usb took 0.0 seconds
2023-02-01 10:06:42.090 INFO (MainThread) [homeassistant.setup] Setting up dhcp
2023-02-01 10:06:42.093 INFO (MainThread) [homeassistant.setup] Setup of domain dhcp took 0.0 seconds
2023-02-01 10:06:42.095 INFO (MainThread) [homeassistant.setup] Setting up network
2023-02-01 10:06:42.100 INFO (MainThread) [homeassistant.setup] Setup of domain network took 0.0 seconds
2023-02-01 10:06:42.140 INFO (SyncWorker_0) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant
2023-02-01 10:06:42.142 INFO (SyncWorker_1) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa
2023-02-01 10:06:42.161 INFO (SyncWorker_0) [homeassistant.loader] Loaded camera from homeassistant.components.camera
2023-02-01 10:06:42.257 INFO (MainThread) [homeassistant.setup] Setting up bluetooth
2023-02-01 10:06:42.264 INFO (MainThread) [homeassistant.setup] Setup of domain bluetooth took 0.0 seconds
2023-02-01 10:06:42.397 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2023-02-01 10:06:42.404 WARNING (MainThread) [asyncio] Executing <Task pending name=‘Task-287’ coro=<_async_setup_component() running at /workspaces/freehandsIntegrations/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[<TaskWakeupMethWrapper object at 0x7f6d25379c70>()] created at /usr/local/lib/python3.9/asyncio/tasks.py:702> cb=[<TaskWakeupMethWrapper object at 0x7f6d26004970>()] created at /workspaces/freehandsIntegrations/homeassistant/core.py:511> took 0.113 seconds
2023-02-01 10:06:42.408 INFO (SyncWorker_1) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2023-02-01 10:06:42.457 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2023-02-01 10:06:42.468 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.1 seconds
2023-02-01 10:06:42.499 INFO (MainThread) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
2023-02-01 10:06:43.056 INFO (MainThread) [homeassistant.setup] Setting up cloud
2023-02-01 10:06:43.060 WARNING (MainThread) [asyncio] Executing <Task pending name=‘Task-290’ coro=<_async_setup_component() running at /workspaces/freehandsIntegrations/homeassistant/setup.py:235> wait_for=<Task pending name=‘Task-341’ coro=<Store._async_load() running at /workspaces/freehandsIntegrations/homeassistant/helpers/storage.py:118> cb=[<TaskWakeupMethWrapper object at 0x7f6cf83678e0>()] created at /workspaces/freehandsIntegrations/homeassistant/core.py:511> cb=[<TaskWakeupMethWrapper object at 0x7f6d26046760>()] created at /workspaces/freehandsIntegrations/homeassistant/core.py:511> took 0.555 seconds
2023-02-01 10:06:43.111 INFO (MainThread) [asyncio] <Server sockets=(<asyncio.TransportSocket fd=17, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=(‘172.17.0.3’, 40000)>,)> is serving
2023-02-01 10:06:43.122 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.1 seconds
2023-02-01 10:06:43.140 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.7 seconds
2023-02-01 10:06:43.155 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {‘input_select’, ‘person’, ‘zone’, ‘analytics’, ‘image’, ‘trace’, ‘logbook’, ‘default_config’, ‘mobile_app’, ‘homeassistant_alerts’, ‘input_boolean’, ‘my’, ‘timer’, ‘blueprint’, ‘schedule’, ‘search’, ‘lovelace’, ‘map’, ‘diagnostics’, ‘device_automation’, ‘sun’, ‘script’, ‘automation’, ‘config’, ‘tag’, ‘input_button’, ‘energy’, ‘auth’, ‘application_credentials’, ‘media_source’, ‘tts’, ‘onboarding’, ‘input_number’, ‘scene’, ‘input_text’, ‘input_datetime’, ‘repairs’, ‘hardware’, ‘radio_browser’, ‘history’, ‘file_upload’, ‘system_health’, ‘counter’}
2023-02-01 10:06:42.689 INFO (MainThread) [homeassistant.setup] Setting up input_select
2023-02-01 10:06:42.694 INFO (MainThread) [homeassistant.setup] Setting up zone
2023-02-01 10:06:42.698 INFO (MainThread) [homeassistant.setup] Setting up trace
2023-02-01 10:06:42.701 INFO (MainThread) [homeassistant.setup] Setup of domain trace took 0.0 seconds
2023-02-01 10:06:42.727 INFO (MainThread) [homeassistant.setup] Setting up homeassistant_alerts
2023-02-01 10:06:42.729 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant_alerts took 0.0 seconds
2023-02-01 10:06:42.732 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2023-02-01 10:06:42.740 INFO (MainThread) [homeassistant.setup] Setting up timer
2023-02-01 10:06:42.744 INFO (MainThread) [homeassistant.setup] Setting up blueprint
2023-02-01 10:06:42.747 INFO (MainThread) [homeassistant.setup] Setup of domain blueprint took 0.0 seconds
2023-02-01 10:06:42.759 INFO (MainThread) [homeassistant.setup] Setting up schedule
2023-02-01 10:06:42.765 INFO (MainThread) [homeassistant.setup] Setting up sun
2023-02-01 10:06:42.769 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds
2023-02-01 10:06:42.777 INFO (MainThread) [homeassistant.setup] Setting up tag
2023-02-01 10:06:42.781 INFO (MainThread) [homeassistant.setup] Setting up input_button
2023-02-01 10:06:42.797 INFO (MainThread) [homeassistant.setup] Setting up input_number
2023-02-01 10:06:42.804 INFO (MainThread) [homeassistant.setup] Setting up scene
2023-02-01 10:06:42.807 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2023-02-01 10:06:42.815 INFO (MainThread) [homeassistant.setup] Setting up input_text
2023-02-01 10:06:42.822 INFO (MainThread) [homeassistant.setup] Setting up input_datetime
2023-02-01 10:06:42.837 INFO (MainThread) [homeassistant.setup] Setting up history
2023-02-01 10:06:42.840 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds
2023-02-01 10:06:42.847 INFO (MainThread) [homeassistant.setup] Setting up counter
2023-02-01 10:06:42.929 INFO (MainThread) [homeassistant.setup] Setting up logbook
2023-02-01 10:06:42.962 INFO (MainThread) [homeassistant.setup] Setting up my
2023-02-01 10:06:42.964 INFO (MainThread) [homeassistant.setup] Setup of domain my took 0.0 seconds
2023-02-01 10:06:42.972 INFO (MainThread) [homeassistant.setup] Setting up map
2023-02-01 10:06:42.974 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds
2023-02-01 10:06:42.977 INFO (MainThread) [homeassistant.setup] Setting up script
2023-02-01 10:06:42.986 INFO (MainThread) [homeassistant.setup] Setting up automation
2023-02-01 10:06:42.998 INFO (MainThread) [homeassistant.setup] Setting up application_credentials
2023-02-01 10:06:43.009 INFO (MainThread) [homeassistant.setup] Setting up media_source
2023-02-01 10:06:43.049 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.2 seconds
2023-02-01 10:06:43.056 INFO (MainThread) [homeassistant.setup] Setting up system_health
2023-02-01 10:06:43.118 INFO (MainThread) [homeassistant.setup] Setup of domain tag took 0.3 seconds
2023-02-01 10:06:43.141 INFO (MainThread) [homeassistant.setup] Setting up energy
2023-02-01 10:06:43.143 INFO (MainThread) [homeassistant.setup] Setup of domain energy took 0.0 seconds
2023-02-01 10:06:43.198 INFO (MainThread) [homeassistant.setup] Setting up hardware
2023-02-01 10:06:43.287 INFO (SyncWorker_1) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2023-02-01 10:06:43.304 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.4 seconds
2023-02-01 10:06:43.330 INFO (MainThread) [homeassistant.setup] Setup of domain media_source took 0.3 seconds
2023-02-01 10:06:43.342 INFO (SyncWorker_1) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2023-02-01 10:06:43.350 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.3 seconds
2023-02-01 10:06:43.374 INFO (MainThread) [homeassistant.setup] Setup of domain timer took 0.6 seconds
2023-02-01 10:06:43.391 INFO (MainThread) [homeassistant.setup] Setup of domain hardware took 0.2 seconds
2023-02-01 10:06:43.405 INFO (MainThread) [homeassistant.setup] Setup of domain counter took 0.6 seconds
2023-02-01 10:06:43.428 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.5 seconds
2023-02-01 10:06:43.433 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.4 seconds
2023-02-01 10:06:43.532 INFO (MainThread) [homeassistant.setup] Setting up radio_browser
2023-02-01 10:06:43.535 INFO (MainThread) [homeassistant.setup] Setup of domain radio_browser took 0.0 seconds
2023-02-01 10:06:43.578 INFO (MainThread) [homeassistant.setup] Setup of domain application_credentials took 0.6 seconds
2023-02-01 10:06:43.588 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 0.9 seconds
2023-02-01 10:06:43.590 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.9 seconds
2023-02-01 10:06:43.599 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 0.9 seconds
2023-02-01 10:06:43.702 INFO (MainThread) [homeassistant.setup] Setup of domain schedule took 0.9 seconds
2023-02-01 10:06:43.719 INFO (MainThread) [homeassistant.setup] Setup of domain input_button took 0.9 seconds
2023-02-01 10:06:43.764 INFO (MainThread) [homeassistant.setup] Setting up tts
2023-02-01 10:06:43.771 INFO (MainThread) [homeassistant.setup] Setting up sensor
2023-02-01 10:06:43.774 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds
2023-02-01 10:06:43.819 INFO (MainThread) [homeassistant.setup] Setup of domain input_number took 1.0 seconds
2023-02-01 10:06:43.825 INFO (MainThread) [homeassistant.setup] Setup of domain input_text took 1.0 seconds
2023-02-01 10:06:43.832 INFO (MainThread) [homeassistant.setup] Setup of domain input_datetime took 1.0 seconds
2023-02-01 10:06:43.884 INFO (SyncWorker_0) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2023-02-01 10:06:43.893 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.energy
2023-02-01 10:06:43.934 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2023-02-01 10:06:43.941 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.2 seconds
2023-02-01 10:06:43.952 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.0 seconds
2023-02-01 10:06:43.962 INFO (MainThread) [homeassistant.setup] Setting up notify
2023-02-01 10:06:43.963 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds
2023-02-01 10:06:44.025 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2023-02-01 10:06:44.033 INFO (MainThread) [homeassistant.setup] Setting up default_config
2023-02-01 10:06:44.042 INFO (SyncWorker_0) [homeassistant.loader] Loaded backup from homeassistant.components.backup
2023-02-01 10:06:44.063 INFO (MainThread) [homeassistant.setup] Setting up backup
2023-02-01 10:06:44.067 INFO (MainThread) [homeassistant.setup] Setup of domain backup took 0.0 seconds
2023-02-01 10:06:44.076 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.0 seconds
2023-02-01 10:06:44.245 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 4.95s
2023-02-01 10:06:44.246 INFO (MainThread) [homeassistant.core] Starting Home Assistant
