107.7 is working just fine, but as soon as I upgrade to 108.X (108.5 was the last I tried), I can’t login to HA webinterface. Just stuck on “Loading data”.
Any browser I had open on the HA interface, before upgrading, keeps working until refreshed - that’s how I managed to downgrade again.
I have HACS and Shelly custom integrations installed.
The log fills up with the below + tons of JSON that looks like it’s the entire definition of the web app - this is excluded from the below log, as it’s just page after page of JSON stuff for every component in my system.
2020-04-15 22:56:09 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for shelly which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-04-15 22:56:09 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-04-15 22:56:24 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-04-15 22:56:24 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 5 seconds.
2020-04-15 22:56:26 ERROR (MainThread) [homeassistant.components.wled] Error fetching wled data: Invalid response from API: Error occurred while communicating with WLED device.
2020-04-15 22:56:26 WARNING (MainThread) [homeassistant.config_entries] Config entry for wled not ready yet. Retrying in 5 seconds.
2020-04-15 22:56:27 ERROR (MainThread) [homeassistant.components.light] Entity id already exists - ignoring: light.d4_light_2. Platform mqtt does not generate unique IDs
2020-04-15 22:56:35 ERROR (MainThread) [homeassistant.components.binary_sensor] Entity id already exists - ignoring: binary_sensor.gpio5. Platform mqtt does not generate unique IDs
2020-04-15 22:56:35 ERROR (MainThread) [homeassistant.components.binary_sensor] Entity id already exists - ignoring: binary_sensor.gpio4. Platform mqtt does not generate unique IDs
2020-04-15 22:56:36 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/src/homeassistant/homeassistant/components/automation/init.py”, line 421, in async_enable_automation
self._async_detach_triggers = await self._async_attach_triggers()
File “/usr/src/homeassistant/homeassistant/components/automation/init.py”, line 450, in _async_attach_triggers
self.hass, conf, self.async_trigger, info
File “/usr/src/homeassistant/homeassistant/components/automation/device.py”, line 31, in async_attach_trigger
return await platform.async_attach_trigger(hass, config, action, automation_info)
File “/usr/src/homeassistant/homeassistant/components/deconz/device_trigger.py”, line 371, in async_attach_trigger
raise InvalidDeviceAutomationConfig
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig
2020-04-15 22:56:38 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2740330832] Unable to serialize to JSON: Object of type builtin_function_or_method is not JSON serializable
