Hi.
I got home from work today and my hassio installation on an RPI3 doesn’t work anymore. I am stuck on the login screen displaying “Loading data”. The “Loading data” screen comes up when trying to access hassio using my private DNS. When I try hassio.local:8123 nothing shows up. I tried uncommenting almost my entire configuration.yaml to no avail. I also did a fresh install and restored from a fully working snapshot. After the restore, the problem returned. I have also tried removing various files in the .storage directory, but this also doesn’t work. I have no idea what more I could do.
I also tried different browsers if cache was a problem, but no solution here. I have looked at other threads with similar issues, but none of the solutions have worked for me.
My log is pasted below. It seems there may be a problem with my tellduslive configuration. I have added this using the Components page on hassio, so do not know how I can remove it without accessing the GUI, nor do I know if it is tellduslive that is actually causing the problem.
2019-01-23 21:29:46 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=38 from 2019-01-23 20:20:10.924514)
2019-01-23 21:29:58 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 272, in _async_add_entity
device_info = entity.device_info
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/tellduslive/entry.py", line 122, in device_info
'model': device['model'].title(),
AttributeError: 'NoneType' object has no attribute 'title'
2019-01-23 21:30:16 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2019-01-23 21:30:30 ERROR (SyncWorker_4) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2019-01-23 21:30:30 ERROR (SyncWorker_10) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2019-01-23 21:30:31 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2019-01-23 21:30:38 ERROR (SyncWorker_13) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2019-01-23 21:30:38 ERROR (SyncWorker_1) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2019-01-23 21:30:43 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2019-01-23 21:30:46 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2019-01-23 21:30:48 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2019-01-23 21:30:58 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2019-01-23 21:30:59 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
