Too much inside my head these days supplying medical equipment domestically, but trying to relax working on the coolest hobby there is
I’ve done this in the past (but deleted it in later on), but can’t get it to work now.
Created an input_boolean
q70r_on_off:
name: Q70R Av På
initial: off
icon: mdi:television-classic
Then created the switch template
switches:
q70r_on_off:
friendly_name: Samsung Q70R Status
value_template: "{{ is_state('input_boolean.q70r_on_off') }}"
turn_on:
- service: script.q70r_skru_paa
entity_id: input_boolean.q70r_on_off
turn_off:
- service: script.q70r_skru_av
- service: input_boolean.turn_off
Then adding adding it to a button-card
Though, it kind of works ONE time, then it stops. To debug, I went backwards using dev-tools and tested by executing the script - works perfect every time.
Then I tried to test the switch.q70r_on_off
but it kind of turn on for a few seconds and turns off again and script is not activated.
And noticed I get these repeatedly in the log now
