Cant get past Prapring Hass.io (this can take up to 20 minutes). This is on a fresh install of Ubuntu 18.04 with the latest Docker CE. I have waited overnight and the system still will not get past this. I have restarted the Docker containers. Rebooted the machine. Ran updates. I have searched online and haven’t found a solution to fix this. Any help would be great.
I hope you are not watching the console to see if Hassio is installed. You need to open a web browser and navigate to http://[IP]:8123
@xndrxw Adding this here in case anyone else comes across it:
You do not want to choose the LVM option when you set up your disk partitioning.
