And this is the output of HAAS after start. I see only one ERROR in “netdisco”
py -m homeassistant --open-ui
Config directory: C:\Users\kdjor\AppData\Roaming.homeassistant
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=toggle>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=restart>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=check_config>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=reload_core_config>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=create>
INFO:homeassistant.bootstrap:Home Assistant core initialized
INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
INFO:homeassistant.loader:Loaded api from homeassistant.components.api
INFO:homeassistant.loader:Loaded http from homeassistant.components.http
INFO:homeassistant.loader:Loaded websocket_api from homeassistant.components.websocket_api
INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
INFO:homeassistant.loader:Loaded introduction from homeassistant.components.introduction
INFO:homeassistant.loader:Loaded tts from homeassistant.components.tts
INFO:homeassistant.loader:Loaded config from homeassistant.components.config
INFO:homeassistant.loader:Loaded history from homeassistant.components.history
INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
INFO:homeassistant.bootstrap:Setting up introduction
INFO:homeassistant.components.introduction:
Hello, and welcome to Home Assistant!
We'll hope that we can make all your dreams come true.
Here are some resources to get started:
- Configuring Home Assistant:
https://home-assistant.io/getting-started/configuration/
- Available components:
https://home-assistant.io/components/
- Troubleshooting your configuration:
https://home-assistant.io/getting-started/troubleshooting-configuration/
- Getting help:
https://home-assistant.io/help/
This message is generated by the introduction component. You can
disable it in configuration.yaml.
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=introduction>
INFO:homeassistant.bootstrap:Setting up recorder
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
INFO:homeassistant.bootstrap:Setting up http
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
INFO:homeassistant.bootstrap:Setting up api
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
INFO:homeassistant.bootstrap:Setting up websocket_api
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=websocket_api>
INFO:homeassistant.bootstrap:Setting up frontend
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
INFO:homeassistant.bootstrap:Setting up logbook
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=logbook, service=log>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
INFO:homeassistant.bootstrap:Setting up sun
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=None, new_state=<state sun.sun=above_horizon; next_rising=2017-03-03T14:34:59+00:00, next_setting=2017-03-03T02:03:11+00:00, elevation=0, azimuth=0, friendly_name=Sun @ 2017-03-02T08:00:14.787666-08:00>>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
INFO:homeassistant.loader:Loaded tts.google from homeassistant.components.tts.google
INFO:homeassistant.bootstrap:Setting up tts
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=tts, service=google_say>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=tts, service=clear_cache>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=tts>
INFO:homeassistant.bootstrap:Setting up config
INFO:homeassistant.loader:Loaded config.group from homeassistant.components.config.group
INFO:homeassistant.loader:Loaded config.core from homeassistant.components.config.core
INFO:homeassistant.loader:Loaded config.hassbian from homeassistant.components.config.hassbian
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=config.group>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=config.core>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=config>
INFO:homeassistant.bootstrap:Setting up history
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
INFO:homeassistant.loader:Loaded sensor.yr from homeassistant.components.sensor.yr
INFO:homeassistant.bootstrap:Setting up sensor
INFO:homeassistant.components.sensor:Setting up sensor.yr
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.yr_symbol, old_state=None, new_state=<state sensor.yr_symbol=unknown; attribution=Weather forecast from yr.no, delivered by the Norwegian Meteorological Institute and the NRK., friendly_name=yr Symbol, entity_picture=//api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png @ 2017-03-02T08:00:14.971168-08:00>>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.yr_symbol, old_state=<state sensor.yr_symbol=unknown; attribution=Weather forecast from yr.no, delivered by the Norwegian Meteorological Institute and the NRK., friendly_name=yr Symbol, entity_picture=//api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png @ 2017-03-02T08:00:14.971168-08:00>, new_state=<state sensor.yr_symbol=1; attribution=Weather forecast from yr.no, delivered by the Norwegian Meteorological Institute and the NRK., friendly_name=yr Symbol, entity_picture=//api.met.no/weatherapi/weathericon/1.1/?symbol=1;content_type=image/png @ 2017-03-02T08:00:16.530842-08:00>>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
INFO:homeassistant.bootstrap:Setting up updater
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
INFO:homeassistant.util.package:Attempting install of netdisco==0.9.1
Command “C:\Users\kdjor\AppData\Local\Programs\Python\Python36\python.exe -u -c “import setuptools, tokenize;file=‘C:\Users\kdjor\AppData\Local\Temp\pip-build-w4gxh5zn\netifaces\setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record C:\Users\kdjor\AppData\Local\Temp\pip-bl27xdtd-record\install-record.txt --single-version-externally-managed --compile --home=C:\Users\kdjor\AppData\Local\Temp\tmpa25d9k_w” failed with error code 1 in C:\Users\kdjor\AppData\Local\Temp\pip-build-w4gxh5zn\netifaces
ERROR:homeassistant.bootstrap:Not initializing discovery because could not install dependency netdisco==0.9.1
INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=title=Invalid config, message=The following components and platforms could not be set up:
- discovery
Please check your config, notification_id=invalid_config, service_call_id=2659749633720-1>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.invalid_config, old_state=None, new_state=<state persistent_notification.invalid_config=The following components and platforms could not be set up:
- discovery
Please check your config; title=Invalid config @ 2017-03-02T08:00:20.461682-08:00>>
INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=2659749633720-1>
INFO:homeassistant.bootstrap:Setting up conversation
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
INFO:homeassistant.core:Starting Home Assistant core loop
INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
INFO:homeassistant.core:Timer:starting
INFO:homeassistant.components.http:Serving / to 192.168.1.87 (auth: True)
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=2017-03-03T14:34:59+00:00, next_setting=2017-03-03T02:03:11+00:00, elevation=0, azimuth=0, friendly_name=Sun @ 2017-03-02T08:00:14.787666-08:00>, new_state=<state sun.sun=above_horizon; next_rising=2017-03-03T14:34:59+00:00, next_setting=2017-03-03T02:03:11+00:00, elevation=15.27, azimuth=111.39, friendly_name=Sun @ 2017-03-02T08:00:14.787666-08:00>>
