Unable to find configuration. Creating default one in /home/name/.homeassistant
Config directory: /home/name/.homeassistant
2019-08-16 10:24:12 INFO (SyncWorker_1) [homeassistant.util.package] Attempting install of pyotp==2.2.7
2019-08-16 10:24:15 INFO (SyncWorker_2) [homeassistant.util.package] Attempting install of PyQRCode==1.2.1
2019-08-16 10:24:18 INFO (SyncWorker_4) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config
2019-08-16 10:24:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded script from homeassistant.components.script
2019-08-16 10:24:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2019-08-16 10:24:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded group from homeassistant.components.group
2019-08-16 10:24:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2019-08-16 10:24:18 INFO (SyncWorker_4) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2019-08-16 10:24:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2019-08-16 10:24:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded http from homeassistant.components.http
2019-08-16 10:24:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2019-08-16 10:24:18 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2019-08-16 10:24:18 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2019-08-16 10:24:18 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2019-08-16 10:24:18 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2019-08-16 10:24:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2019-08-16 10:24:18 INFO (SyncWorker_4) [homeassistant.loader] Loaded config from homeassistant.components.config
2019-08-16 10:24:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2019-08-16 10:24:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded api from homeassistant.components.api
2019-08-16 10:24:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2019-08-16 10:24:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2019-08-16 10:24:18 INFO (SyncWorker_4) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2019-08-16 10:24:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2019-08-16 10:24:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2019-08-16 10:24:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded history from homeassistant.components.history
2019-08-16 10:24:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2019-08-16 10:24:18 INFO (SyncWorker_4) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2019-08-16 10:24:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded map from homeassistant.components.map
2019-08-16 10:24:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
2019-08-16 10:24:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded person from homeassistant.components.person
2019-08-16 10:24:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2019-08-16 10:24:18 INFO (SyncWorker_4) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2019-08-16 10:24:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
2019-08-16 10:24:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2019-08-16 10:24:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2019-08-16 10:24:18 INFO (MainThread) [homeassistant.bootstrap] Setting up {‘system_log’}
2019-08-16 10:24:18 INFO (SyncWorker_0) [homeassistant.util.package] Attempting install of aiohttp_cors==0.7.0
2019-08-16 10:24:23 INFO (MainThread) [homeassistant.setup] Setting up http
2019-08-16 10:24:23 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-08-16 10:24:23 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-08-16 10:24:23 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-08-16 10:24:23 INFO (SyncWorker_3) [homeassistant.util.package] Attempting install of sqlalchemy==1.3.5
2019-08-16 10:24:28 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-08-16 10:24:28 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.5 seconds.
2019-08-16 10:24:28 INFO (MainThread) [homeassistant.setup] Setting up sun
2019-08-16 10:24:28 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds.
2019-08-16 10:24:29 INFO (SyncWorker_4) [homeassistant.util.package] Attempting install of netdisco==2.6.0
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setting up person
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setting up group
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setting up history
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setting up system_health
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setting up script
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2019-08-16 10:24:29 INFO (MainThread) [homeassistant.setup] Setting up config
2019-08-16 10:24:30 INFO (MainThread) [homeassistant.setup] Setting up api
2019-08-16 10:24:30 INFO (MainThread) [homeassistant.setup] Setting up webhook
2019-08-16 10:24:30 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2019-08-16 10:24:30 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-08-16 10:24:30 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-08-16 10:24:30 INFO (MainThread) [homeassistant.setup] Setup of domain person took 1.2 seconds.
2019-08-16 10:24:30 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.1 seconds.
2019-08-16 10:24:30 INFO (MainThread) [homeassistant.setup] Setup of domain config took 1.2 seconds.
2019-08-16 10:24:30 INFO (MainThread) [homeassistant.setup] Setting up automation
2019-08-16 10:24:30 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2019-08-16 10:24:30 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2019-08-16 10:24:30 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds.
2019-08-16 10:24:34 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2019-08-16 10:24:34 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds.
2019-08-16 10:24:34 INFO (SyncWorker_2) [homeassistant.util.package] Attempting install of distro==1.4.0
2019-08-16 10:24:37 INFO (MainThread) [homeassistant.setup] Setting up updater
2019-08-16 10:24:37 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2019-08-16 10:24:37 INFO (SyncWorker_3) [homeassistant.util.package] Attempting install of mutagen==1.42.0
2019-08-16 10:24:40 INFO (SyncWorker_1) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2019-08-16 10:24:40 INFO (SyncWorker_2) [homeassistant.util.package] Attempting install of hass-nabucasa==0.16
2019-08-16 10:25:01 INFO (MainThread) [homeassistant.setup] Setting up cloud
2019-08-16 10:25:02 INFO (SyncWorker_0) [homeassistant.util.package] Attempting install of PyNaCl==1.3.0
2019-08-16 10:25:03 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 1.3 seconds.
2019-08-16 10:25:07 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2019-08-16 10:25:07 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2019-08-16 10:25:07 INFO (SyncWorker_4) [homeassistant.util.package] Attempting install of home-assistant-frontend==20190805.0
2019-08-16 10:25:07 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.1 seconds.
2019-08-16 10:25:07 INFO (SyncWorker_3) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2019-08-16 10:25:07 INFO (MainThread) [homeassistant.setup] Setting up notify
2019-08-16 10:25:07 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds.
2019-08-16 10:25:07 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2019-08-16 10:25:08 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.8 seconds.
2019-08-16 10:25:14 INFO (MainThread) [homeassistant.setup] Setting up frontend
2019-08-16 10:25:14 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2019-08-16 10:25:14 INFO (SyncWorker_0) [homeassistant.util.package] Attempting install of gTTS-token==1.1.3
2019-08-16 10:25:14 INFO (MainThread) [homeassistant.setup] Setting up logbook
2019-08-16 10:25:14 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2019-08-16 10:25:15 INFO (MainThread) [homeassistant.setup] Setting up map
2019-08-16 10:25:15 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2019-08-16 10:25:15 INFO (MainThread) [homeassistant.setup] Setting up default_config
2019-08-16 10:25:15 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.0 seconds.
2019-08-16 10:25:18 INFO (MainThread) [homeassistant.setup] Setting up tts
2019-08-16 10:25:18 INFO (SyncWorker_2) [homeassistant.components.tts] Create cache dir /home/name/.homeassistant/tts.
2019-08-16 10:25:18 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.0 seconds.
2019-08-16 10:25:18 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 65.56s
2019-08-16 10:25:18 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2019-08-16 10:25:18 INFO (MainThread) [homeassistant.core] Timer:starting
So I’ve installed hass 0.97.2 in my python virtual environment, and upon running it, I am stuck with the Timer:starting issue. I’m running Ubuntu 18.04.3. Does anyone know how to get past this issue?
