Stuck trying to integrate with Leviton devices
I’ve been using Home Assistant now for a few months, super happy. I’ve integrated everything, apart from ONE set of devices. I have the following Leviton:
  • 3xDW15P Plugin Outlet
  • 1xDW6HD Dimmer switch
  • 3xD215P Plug in Outlet
  • D215R Wire in Outlet
Home Assistant by default finds a few of them. I see three plugs and one outlet showing in my discovered devices list, all 4 of them are marked as HomeKit devices. Note I don’t use HomeKit at all in my house.
But I want to be able to integrate all of the Leviton devices. So I looked at the options in Add Integration and saw Leviton Decora WiFi. Leviton Decora Wi-Fi - Home Assistant
I added the section to my configuration.yaml, restarted Home Assistant. But nothing happens. I’ve doubled checked the email and password I am using, it’s correct.
When I try to look at the system logs, I can’t see to get them. If I click on Download, it fails. If I click on Load Logs, it gets stuck on “Loading full log…”
Any ideas how I can diagnose this integration?
