I don’t know what else to do, Ive ben trying to install HAOS for a couple of hours but Im still stuck in the preparing Home Assistant part.
I started following this guide by @troy : “https:community.home-assistant.io/t/installing-haos-in-a-vm-on-truenas-scale/511393” and it worked great but when I go to homeassistant:8123/ and look at the logs, Im stuck in a loop:
23-12-09 13:04:41 ERROR (SyncWorker_1) [supervisor.docker.interface] Can’t install .ghcr.io/home-assistant/qemux86-64-homeassistant:2023.12.1: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2023.12.1&.fromImage=.ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error (“Get “https://ghcr.io/v2/”: dial tcp: lookup ghcr.io: no such host”)
23-12-09 13:04:41 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
I dont know what to do, Ive try to restart from scratch and I get the same result. Also I cant ping any web from the TrueNas VM shell. I guess it has something to with dns but Im kinda new with these things.
Any thoughts?
