Stuck with LetsEncrypt - can't verify and can't get certificate using noip.com
I tried to look for a solution in forum but had no luck. And I’m stuck with that for some time, maybe someone will help me.
So. My environment/ setup:
  • Home Assistant OS 5.12 + supervisor-2021.03.6 + core-2021.3.4
  • Installed Let’s Encrypt (version: 4.11.0)
  • Running everything on a Virtual Machine on Synology NAS. Installed HA OS from an official image.
  • I have static local IP for my HomeAssistant (running on a default 8123 port) and static external IP for my house
  • I forwarded ports in my router to be able to access my HA from outside:
    ** 8123 -> local home assistant IP : 8123 port
    ** 80 -> local home assistant IP : 8123 port
    ** 443 -> local home assistant IP : 8123 port
  • I added DNS at noip.com to be able to access my HomeAssistant via domain, not IP (it works)
  • Before that I tried Synology, DuckDNS and other providers - I had same situation, so I presume it’s not about DNS provider
  • I can use my HA installation from local network and external URL
But once I try to install SSL (i need that for several addons) - It fails. Here is my config:
email: [--HIDDEN--]
domains:
  - [--HIDDEN--]
certfile: fullchain.pem
keyfile: privkey.pem
challenge: http
dns: {}
And this is what I see in my logs:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] file-structure.sh: executing...
[cont-init.d] file-structure.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[14:38:15] INFO: Selected http verification
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator standalone, Installer None
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for [--HIDDEN--]
Waiting for verification...
Challenge failed for domain [--HIDDEN--]
Cleaning up challenges
Some challenges have failed.
IMPORTANT NOTES:
 - The following errors were reported by the server:
   Domain: [--HIDDEN--]
   Type:   unauthorized
   Detail: Invalid response from
   http://[--HIDDEN--]/.well-known/acme-challenge/5Sae-6Weibxr2fhyTT--iqc_JY7gnmwoybgQoRYKgJA
   [--HIDDEN--]: 404
   To fix these errors, please make sure that your domain name was
   entered correctly and the DNS A/AAAA record(s) for that domain
   contain(s) the right IP address.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Question: what should I do and how should I proceed with that LetsEncrypt plugin so I would get certificate?
P.S. I presume something is wrong because even tho it’s written “Saving debug log to /var/log/letsencrypt/letsencrypt.log” - my “/var/log” is empty. No directories, no files.
Thanks!
Ok. So after some time I decided to test once again with DuckDNS - ant it worked from the 1st time… Have no clue why noip.com was/is not working with this setup…
