Stuck with Utility Meter configuration
New with home assistant but i am getting stuck with the config of the utility meter.
I followed this topic Energy, Gas and Water consumption overview for creating an energy and gas consumption overview
I have checked my files and codes on errors but there everything looks good.
Now everytime when i try to restart home assistant i get the error below.
The system cannot restart because the configuration is not valid: Invalid config for [utility_meter]: [hourly_energy_offpeak] is an invalid option for [utility_meter]. Check: utility_meter->utility_meter->utility_meter->hourly_energy_offpeak. (See /config/configuration.yaml, line 13).
i have checked the documentation regarding the utility meter and every parameter i have used is a valid one.
Search this forum and the internet but i just cant find the reason why it is failing
This the code i used for the utility meter
utility_meter:
  hourly_energy_offpeak:
    source: sensor.energy_consumption_tarif_1
    cycle: hourly
  hourly_energy_peak:
    source: sensor.energy_consumption_tarif_2
    cycle: hourly
  hourly_gas:
    source: sensor.gas_consumption
    cycle: hourly
  daily_energy_offpeak:
    cycle: daily
  daily_energy_peak:
    cycle: daily
  daily_gas:
    cycle: daily
  weekly_energy_offpeak:
    cycle: weekly
  weekly_energy_peak:
    cycle: weekly
  weekly_gas:
    cycle: weekly
  monthly_energy_offpeak:
    cycle: monthly
  monthly_energy_peak:
    cycle: monthly
  monthly_gas:
    cycle: monthly
  yearly_energy_offpeak:
    cycle: yearly
  yearly_energy_peak:
    cycle: yearly
  yearly_gas:
    cycle: yearly
in the confguration.yaml i point to this config via
utility_meter: !include utilitymeter.yaml
Now the error shows it is failing on hourly_energy_offpeak but if i remove this it will fail on the next line and so on.
Running HASS on a docker environment version: core-2021.8.6
Hopefully i have explained it correctly and somebody can help me out.
Remove the first line of your utilitymeter.yaml file, utility_meter: as this is already in your configuration.yaml file, when your write:
# ^^^^^ already exists.
The way you have it now the include resolves to:
utility_meter:
  utility_meter:
      cycle: hourly
Too many utility_meter: s
As well as removing the first line, shift your config to the margin so your utilitymeter.yaml file contents look like this:
  cycle: hourly
hourly_energy_peak:
  cycle: hourly
hourly_gas:
  cycle: hourly
  cycle: daily
daily_energy_peak:
  cycle: daily
daily_gas:
  cycle: daily
  cycle: weekly
weekly_energy_peak:
  cycle: weekly
weekly_gas:
  cycle: weekly
  cycle: monthly
  cycle: monthly
monthly_gas:
  cycle: monthly
  cycle: yearly
yearly_energy_peak:
  cycle: yearly
yearly_gas:
  cycle: yearly
serious i will never forget this mistake :slight_smile:
didn’t know it worked that way, so simple afterwards and was messing with it for hours :frowning:
many many thanks!!
I am trying to implement this, however i would like to have the utility meters in a seperate map/files.
In my configuration.yaml, this works:
utility_meter: !include entities/utilitymeters/energy.yaml
But this, does not work:
utility_meter: !include_dir_named /entities/utilitymeters
I have no idea why, al other includes maps do work with !include_dir_… ?
Hi there,
just for everyone who is also trying and dying:
there are no capital letters allowed in the names of the variables:
so this does work:
  utility_meter:
      cycle: hourly
but this not:
  utility_meter:
    Hourly_Energy_Offpeak:
      cycle: hourly
Maybe I can save someone some time :wink:
Greetings,
Alex
Thank you very very much @axel_schweiss to have taken your time to write about it. I almost spent the whole morning trying to figuring this out!
Just here to tell you, you just did :slight_smile:
many, many thanks!
I never would have figured it out
I have spent too many hours trying to figure out the issue and the difference between the ones working and those not, thanks!
