Hi, folks!
I am trying to pair a few devices (ikea switches and remotes and aqara cube) with zigbee2mqtt and I just cannot do it. These are the steps I made til now. Did I do something wrong?
These are the steps I took
-Prepare the USB dongle. There are a few steps I did here, but mainly I followed this tut right here https://notenoughtech.com/home-automation/flashing-cc2531-without-cc-debugger/
-Create a new user that will manage everything mqtt related by going to Configuration -> Users. Note: This name cannot be homeassistant or addon, those are reserved usernames. Use this name and password for Mosquitto Broker and zigbee2mqtt
Mosquitto broker
-Go to Supervisor -> Add-on store -> install MQTT broker.
-Set it up and start it
Configuration file should look something like this
logins:
- username: USERNAME
password: PASSWORD
anonymous: false
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
zigbee2mqtt
-Go to https://github.com/danielwelch/hassio-zigbee2mqtt and add it as a new repository
-Install zigbee2mqtt
-Go to configuration and change the user and password to match the one in the Mosquitto Broker and go to Superviser -> System and press the 3 dotted line on Host system and select Hardware. Copy the long string on serial. Something with Texas in it. (ex: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0008B86866-if00) That is the serial port for the USB dongle
-Change the mqtt server address to ‘mqtt://[IP_of_HA]:[PORT]’. Port should be the port for mqtt. Same as the broker.
-Change the permi_join to true when pairing devices. Change it back to false afterwards for security reasons
Configuration file should look something like this:
data_path: /share/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: 'mqtt://[IP_of_HA]:1883'
user: USERNAME
password: PASSWORD
serial:
port: >-
advanced:
log_level: info
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
experimental: {}
socat:
enabled: false
master: 'pty,raw,echo=0,link=/dev/ttyZ2M,mode=777'
slave: 'tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5'
restartdelay: 1
initialdelay: 1
options: '-d -d'
log: false
-Save the config and restart the add-on
-Restart HA
-Go to the Mosquitto broker add-on and check the logs. Then go to ZigBee2MQTTand check the logs. There should not be any errors.
Some extra unnecessary steps
-Add this to your configuration.yaml to integrate in Lovelace on/off options for Allowing devices to join
mqtt:
broker: core-mosquitto # This will have to be your MQTT broker, Mosquitto add-on is recommended.
discovery: true
input_boolean:
zigbee_permit_join:
name: Allow devices to join
initial: off
icon: mdi:cellphone-wireless
timer:
zigbee_permit_join:
name: Time remaining
duration: 600 # Updated this to the number of seconds you wish
- platform: mqtt
state_topic: "zigbee2mqtt/bridge/state"
icon: mdi:router-wireless
And this to automations.yaml
automation:
- id: enable_zigbee_join
alias: Enable Zigbee joining
platform: state
entity_id: input_boolean.zigbee_permit_join
to: 'on'
- service: mqtt.publish
topic: zigbee2mqtt/bridge/config/permit_join
payload: 'true'
- service: timer.start
entity_id: timer.zigbee_permit_join
- id: disable_zigbee_join
alias: Disable Zigbee joining
- entity_id: input_boolean.zigbee_permit_join
platform: state
to: 'off'
- data:
payload: 'false'
- data:
service: timer.cancel
- id: disable_zigbee_join_timer
alias: Disable Zigbee joining by timer
- platform: event
event_type: timer.finished
event_data:
payload: 'false'
- service: input_boolean.turn_off
And this as an entities:
type: entities
entities:
- entity: input_boolean.zigbee_permit_join
- entity: timer.zigbee_permit_join
- entity: sensor.bridge_state
show_header_toggle: false
title: Zigbee
