I’d like to add a link from a post I’ve made so I don’t have to recreate them here:
opened 12:55PM - 16 Jul 22 UTC
integration: hassio
### The problem
### Is there an existing issue for this?
- [X] I have sear… ched the existing issues
### OS/Web Information
- Web Browser: Chrome
- Local OS: Windows 10
- Remote OS: Ubuntu
- Remote Architecture: amd64:5.1.2
- `code-server --version`: 5.1.2
### Expected
Based on the docs, it should start after I installed it.
### Actual
It throws a message that it failed to start the add-on based on this image ![](https://i.imgur.com/dQ9wCHr.png)
### Screenshot/Video
![](https://i.imgur.com/9jQqneS.gif)
### What version of Home Assistant Core has the issue?
Home Assistant OS 8.2
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
Home Assistant Supervisor
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/hassio
### Diagnostics information
### Example YAML snippet
```yaml
init_commands: []
packages: []
### Anything in the logs that might be useful for us?
```txt
Logger: homeassistant.components.hassio
Source: components/hassio/websocket_api.py:122
Integration: Home Assistant Supervisor ([documentation](https://www.home-assistant.io/integrations/hassio), [issues](https://github.com/home-assistant/core/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+hassio%22))
First occurred: 8:41:52 PM (2 occurrences)
Last logged: 8:42:03 PM
Failed to to call /addons/a0d7b954_vscode/start - Image ghcr.io/hassio-addons/vscode/amd64:5.1.2 does not exist for addon_a0d7b954_vscode
### Additional information
### Notes
I am using Home Assistant and used its local address to let me run it in the browser. I was trying to follow a [video tutorial](https://youtu.be/sVqyDtEjudk?t=599) from 2020, with the current time of the video when trying to install Studio Code Server. I really don't know how to configure them directly into the add-on because the UI of the video is so different. The configuration looked different and when I edit it, it keeps disappearing and doesn't save upon refresh (which is something that I'll try again if that's the fix). I end up leaving it [empty](https://i.imgur.com/LnVriKK.png) because I don't know anything. When I start the add-on it [fails to start](https://i.imgur.com/dQ9wCHr.png) it's hard to find any good search results on Google and I'm completely stumped to make my own issue here. I hope I can get a good solution for this thanks.
Updated errors in regards to this issue:
This is what happens when I install Studio Code Server.
![](https://i.imgur.com/44LUiZm.gif)
from all of those persistent wave of errors, it caused the system to re-boot by itself.
Meanwhile back in the frontend UI of Home Assistant, the buffers of the installation had finally show results and it says "Install Failed see supervisor logs"
Here are the logs of the failed installation:
I’m trying to use Home Assistant as a hub so I don’t have to buy a hub anyway. But I ran into to obstacle that made me feel stuck is that my add-on wouldn’t start because of an error. I needed Studio Code Server in order to get started with my smart home applications as I heard it’s very used in certain ways.
I would like to know if anyone has an idea for a fix about this. I couldn’t find any results similar to mine. It would be grateful to find good solutions for this so anyone can do it.
