I have posted on reddit and opened an issue in the repo but, maybe someone here has some advice. I dont use VSCode as my daily IDE so maybe I am missing a config option.
Basically, if I am trying to get entities autocomplete, I can only get it in configuration.yaml
. If I !include some_file.yaml
and then start editing some_file.yaml
, I can not get autocompletion of entities.
Example
Autocompletion works
configuration.yaml
emulated_hue:
type: alexa
host_ip: 10.0.1.20
listen_port: 80
expose_by_default: false
entities:
light.room_overhead:
name: "Room overhead"
hidden: false
When I start typing the entity name light.
I get autocompletion
Autocompletion does not work
configuration.yaml
emulated_hue: !include emulated_hue.yaml
emulated_hue.yaml
type: alexa
host_ip: 10.0.1.20
listen_port: 80
entities:
hidden: false
When I type light.
I get no autocomplete.
The Home Assistant Config Helper is installed and says it is enabled globally.
How can I get autocompletion of entities in !include
linked files? It seems to me that this would be a feature worth having.
TIA!
