This is a stupid coding question but for the life of me I cannot figure out what I am doing wrong here. I am trying to declare multiple arrays in a function on one line and no matter what I have tried only separating each individual declaration works. And to be clear I am not doing all three at the same time, that is just for display purposes otherwise obviously it’s going to tell you that you have duplicate array names.
//Define Test Arrays
// These are the three examples. 2 don't work 1 does.
//DOESN'T WORK
var test1={}, test2={}, test3={}, test4={};
//DOESN'T WORK
var test1,test2,test3,test4 = {};
//DOESN'T WORK
var test1=[],test2=[],test3=[],test4=[];
//WORKS
var test1 = {}
var test2 = {}
var test3 = {}
var test4 = {}
Appreciate the help. Here is the full function. Nothing fancy just a hand full of tests. The error when using the other was undefined payload which would be coming from test1.payload assignment because it didn’t assign the array properly.
//var test1={}, test2={}, test3={}, test4={};
var test1 = {}
var test2 = {}
var test3 = {}
var test4 = {}
// Get states and put them into a global array
var states = global.get('homeassistant.homeAssistant.states');
// TEST1 Check Inside Temp
if (msg.data.attributes.current_temperature > 72) {
test1.payload = true
test1.topic = "ac_on1"
} else {
msg.payload = false
// TEST2 Check Hold Messages
if (global.get('ignore_ac')) {
test2.payload = false
test2.topic = "ac_on2"
} else {
test2.payload = true
// TEST3 Season
if (states["sensor.season"].state != "winter") {
test3.payload = true
test3.topic = "ac_on3"
} else {
test3.payload = false
// TEST4 Outside Temp
if (states["sensor.openweathermap_temperature"].state > 70) {
test4.payload = true
test4.topic = "ac_on4"
} else {
test4.payload = false
return [ test1, test2, test3, test4 ];
