Hi there,
I have created an automation (draft) that should remind me of open windows via Alexa.
The design looks like this:
alias: Fensterwarnung Arbeitszimmer
description: ''
- type: opened
platform: device
device_id: a3b660743a3ade9f221523df6512bbe7
entity_id: binary_sensor.lumi_lumi_sensor_magnet_aq2_19330507_on_off
domain: binary_sensor
for:
hours: 0
minutes: 0
seconds: 30
condition:
- condition: state
entity_id: sensor.moritz_aussentemperature_wrg
state: <6
- repeat:
count: '4'
sequence:
- service: media_player.play_media
media_content_id: amzn_sfx_lightning_strike_02
media_content_type: sound
entity_id:
- media_player.arbeitszimmer
- media_player.eva_s_bose_smart_soundbar_300
- media_player.bad
- media_player.terrasse
- media_player.workstatt
- media_player.moritz
- media_player.torstens_echo_dot
- service: notify.alexa_media
message: >-
Fenster im Arbeitszimmer sind schon länger geöffnet. Bitte wieder
schlieĂźen
- media_player.bad
type: tts
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
mode: single
Two questions about this:
How can I ensure that the automation is canceled when the corresponding window is closed again?
I have built in the condition that the automation only starts at a certain temperature. Did I do it correctly “<6”?
Many Thanks.
Greetings Werner
tom_l
January 5, 2022, 3:52pm
2
condition:
- condition: numeric_state
below: 6
To cancel it you could use the repeat until loop instead of just repeat.
Hi there,
Thanks very much. I already thought that the temperature setting was wrong.
Unfortunately, I don’t understand that with repeating to the loop.
I only have the choice of “number”, “until condition” or “during condition”.
Greetings Werner
finity
January 5, 2022, 8:54pm
4
The “repeat until” documentation is here
you can use the condition to be until the window is closed or you can use a template condition that uses the repeat.index value of 4 so that it will repeat until the window is closed or the action repeats for 4 times.
I believe this should work:
- repeat:
sequence:
entity_id:
- media_player.bad
message: >-
schlieĂźen
- media_player.bad
type: tts
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
until:
- condition: or
conditions:
- condition: template
value_template: "{{ repeat.index == 4 }}"
- condition: state
state: 'off'
(Taras)
January 5, 2022, 9:20pm
5
Here’s essentially what everyone has suggested you do except it uses:
description: ''
- platform: state
to: 'on'
for: '00:00:30'
condition: "{{ states('sensor.moritz_aussentemperature_wrg')|float(0) < 6 }}"
- variables:
players:
- media_player.bad
- repeat:
while: "{{ is_state('binary_sensor.lumi_lumi_sensor_magnet_aq2_19330507_on_off', 'on') and repeat.index <= 4 }}"
sequence:
entity_id: '{{ players }}'
message: 'Fenster im Arbeitszimmer sind schon länger geöffnet. Bitte wieder schließen'
target: '{{ players }}'
type: tts
- delay: '00:00:30'
mode: single
Hi there,
Thanks very much. It works great. I used the solution from [Endlichkeit] (Profile - finity - Home Assistant Community ) because I can still edit it in the user interface.
I still have a small problem:
I took sounds from this website:
Alexa Skills Kit Sound Library | Alexa Skills Kit
However, the sound amzn_sfx_lightning_strike_02 does not work. However, amzn_sfx_doorbell_chime_01 works.
What can be the reason?
Greetings Werner
123
(Taras)
January 6, 2022, 6:00pm
7
Although there are many sound effects, you are limited to using the ones that are listed in the Alexa app. That’s because the Alexa Media Player integration uses the same control interface as the Alexa app.
I see. OK. How do I find the names of the available sounds?
Thank you.
Greetings Werner
123
(Taras)
January 6, 2022, 7:58pm
9
They are listed in the Alexa Media Player’s documentation:
Known available sounds
