Styling elements in Picture elements card: a small tutorial
reserved post 18
reserved post 19
reserved post 20
Awesome, i really appretiate your work here!:):
Does anyonne know how to make the hitbox of the icons bigger and how to remove the shadow of the picturelement?
I want to get rid of the black line at the bottom.
type: picture-elements
elements:
  - type: icon
    icon: mdi:chevron-up
    tap_action:
      action: call-service
      service: script.fernseher_up
    style:
      top: 18%
      left: 50%
      transform: translate(-50%, -50%) scale(2, 2)
Great examples. How would you set the height of an image element based on a sensor value?
The use case is using overlays with transparent parts over the main image to show levels in tanks.
The element size is better to set dynamically by card-mod since it supports templates.
Hi!
I’m building my floorplan with picture-elements card and I run into a problem: I cannot change the icon color of a switch when it is turned on.
My code is the following:
          - type: state-icon
            tap_action:
              action: toggle
            entity: light.terasz_szoba_lampa
            style:
              bottom: 33%
              right: 7%
              border-radius: 50%
              "--paper-item-icon-color": black
              "--paper-item-icon-active-color" : yellow
              text-align: center
              background-color: rgba(102, 102, 102, 0.2)
I’d like to have the “switched on” color yellor.
Any ideas? :slight_smile:
Useless here since there is no name displayed.
This works - you may check it if change “black” to “cyan” to be sure.
This does not work due to the light entity.
Check this:
elements:
  - type: state-icon
    entity: light.virtual_light_1
    tap_action: &ref_tap_action
      action: toggle
    style:
      bottom: 33%
      right: 7%
      <<: &ref_settings
        border-radius: 50%
        '--paper-item-icon-color': cyan
        '--paper-item-icon-active-color': red
  - type: state-icon
    entity: input_boolean.test_boolean
    tap_action: *ref_tap_action
    style:
      bottom: 53%
      right: 7%
      <<: *ref_settings
image: /local/images/blue.jpg
It works for the input_boolean entity and does not for the light entity.
You need to “override” this by some way - kind of using “!important” in CSS.
Seems that card-mod may be the only solution (provided here).
Hi all,
Thanks for all these great ideas!
Is there any way to rotate an icon according a variable?
Let’s say, something like this:
 - type: icon
     icon: mdi:bike
     style:
       top: 38%
       right: 7%
       transform:
         rotate({{ states('sensor.mower_yaw')|int  }}deg)
It is to set an icon according the position of the mower.
Check this.
Specify a variable by card-mod, then use it.
It sound easy… but how I specify and use it?
type: vertical-stack
cards:
  - type: entities
    entities:
      - entity: input_number.test_number
  - type: picture-elements
    style: |
      ha-card {
        {% set ANGLE = states('input_number.test_number') + 'deg' %}
        --my-transform-style: translate(-50%,-50%) rotate({{ANGLE}});
    elements:
      - type: icon
        icon: mdi:arrow-up-thin
        style:
          top: 18%
          color: orange
          left: 20%
          transform: var(--my-transform-style)
Nice!
Really appreciated!!
Still cannot use as icon, but this is another option.
Thanks again
Nop. Copy/pasted the code, created the test_number and the image, but does not rotate
Anyway, I will keep trying with this idea.
Did you try changing a value of the input_number?
Or do you expect a continuous rotation?
I did, yes. You can see it in my picture.
I see in your picture that worked for you, but for any reason it does not rotate mine.
Do you have card-mod installed?
Yes, I have it installed
Then check again. Copy / paste exactly my code, check if the input_number is created.
Check whether you card-mod working with a simple examples, is it of the latest version.
Paste that code into the Template (dev-tool):
{{ANGLE}}
See what it returns:
