I have create a sublow to manage all notification service, and I tell myself that it can be cool to share it ![]()
It is still under development and I am gradually adding the different services that I use.
Actualy, you can notify :
- HTML5 by Home Assistant
- Discord
- Home Assistant (application mobile)
- Telegram
- TTS
Screenshot :
You can download it here.
Docs :
Information
This flow aims to centralize all notifications.
Actualy, it’s work with :
- HTML5 (by Home Assistant)
- Discord
- Telegram
- TTS
- Home Assistant (Mobile App)
Requirement
- node-red-contrib-chatbot
- node-red-contrib-chatbot-discord
- node-red-contrib-string
- node-red-contrib-home-assistant-websocket
- node-red-node-email
Input
In this exemple, you can find all inut :
msg.title = "Home Assistant - New version available"
msg.dest = "tel_clement;mail_clement;tts_80_hall"
msg.message = "Home Assistant : New version available => 0.113.0 \n
https://github.com/home-assistant/core/releases/tag/0.113.0"
msg.short_message = "Home Assistant : New version available (0.113.0)"
msg.image = "/data/image.jpeg"
msg.document = "/data/doc.js"
msg.video = "/data/video.mp4"
All inputs are not necessarily compatible with all services
Title / msg.title
Available on : Email
Title use only for email
Exemple:
Message / msg.message
Available on : Email / Telegram / Discord
Long version of message
Exemple:
msg.message = "Home Assistant : New version available => 0.113.0 \n https://github.com/home-assistant/core/releases/tag/0.113.0"
Short Message / msg.short_message
Available on : HTML5 / Home Assistant
Short Message use in "popup’
Exemple:
WARNING : Message are Trim & \n replace by space
=> If not set, i take msg.message.
Image / msg.image
Available on : Telegram
Exemple:
msg.image = "https://cdn.pixabay.com/photo/2015/04/23/22/00/tree-736885__340.jpg"
Document / msg.document
Exemple:
Video / msg.video
Exemple:
Destination / msg.dest
Available on : All
Is a string to contains all destination separated by “;”
Exemple:
Message send to :
- tel_clement
- mail_clement
- tts_80_hall
HTML5
This dest is always notify, you don’t need to add this dest.
Discord
Dest must start by discord_
Exemple:
msg.dest = "discord_communaute_news;discord_maison_information;discord_maison_network"
Home Assistant
Dest must start by tel_
Exemple:
msg.dest = "tel_clement;tel_papa;tel_maman
Dest must start by mail_
Exemple:
msg.dest = "mail_clement;mail_thomas"
Telegram
Dest must start by telegram_
Exemple:
msg.dest = "telegram_smarthome;telegram_familly"
TTS
Dest must start by tts_
Format : tts_{VOLUME}_{ENTITY_ID_OF_MEDIA_PLAYER}
Exemple:
msg.dest = "tts_80_hall"
Configuration
Subflow get configuration in global variable notif.
TTS no need configuration
Exemple:
// Discord channel ID
var discord = {
"discord_communaute_news": XXXXXX,
"discord_maison_general": XXXXXX,
"discord_maison_alert": XXXXXX,
"discord_maison_information": XXXXXX,
"discord_maison_network": XXXXXX,
"discord_maison_volets": XXXXXX,
// Entity ID of your phone
var home_assistant = {
"tel_clement": "mobile_app_oneplus_a6010",
"tel_nathalie": "mobile_app_oneplus_a5000"
// Email
var email = {
"mail_1": "[email protected]",
"mail_2": "[email protected]",
"mail_3": "[email protected]"
// Telegram channel_id
var telegram = {
"telegram_smarthome": "-channel_id",
"telegram_serie": "-channel_id",
"telegram_film": "-channel_id"
global.set("notif.discord",discord);
global.set("notif.home_assistant",home_assistant);
global.set("notif.email",email);
global.set("notif.telegram",telegram);
You can take this flow to help you to configure sublow ![]()
[{"id":"eeef2d85.9fa7","type":"inject","z":"711f44dc.b8379c","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":190,"y":440,"wires":[["487a6ba5.82acf4","9492f68.6dd8208"]]},{"id":"9492f68.6dd8208","type":"function","z":"711f44dc.b8379c","name":"Config Exemple","func":"// Discord channel ID\nvar discord = {\n \"discord_communaute_news\": XXXXXX,\n \"discord_maison_general\": XXXXXX,\n \"discord_maison_alert\": XXXXXX,\n \"discord_maison_information\": XXXXXX,\n \"discord_maison_network\": XXXXXX,\n \"discord_maison_volets\": XXXXXX,\n}\n\n// Entity ID of your phone\nvar home_assistant = {\n \"tel_clement\": \"mobile_app_oneplus_a6010\",\n \"tel_nathalie\": \"mobile_app_oneplus_a5000\"\n}\n\n// Just email\nvar email = {\n \"mail_1\": \"[email protected]\",\n \"mail_2\": \"[email protected]\",\n \"mail_3\": \"[email protected]\"\n}\n\n// Just channel_id\nvar telegram = {\n \"telegram_smarthome\": \"-channel_id\",\n \"telegram_serie\": \"-channel_id\",\n \"telegram_film\": \"-channel_id\"\n}\n\n// TTS\n// No configuration \n// Ex : tts_80_hall\n// => Volume 80%\n// => media_player.hall\n\nglobal.set(\"notif.discord\",discord);\nglobal.set(\"notif.home_assistant\",home_assistant);\nglobal.set(\"notif.email\",email);\nglobal.set(\"notif.telegram\",telegram);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":380,"y":440,"wires":[[]]}]
Exemple of input :
[{"id":"66da3fb7.1e4ff","type":"change","z":"8a8a63c5.0c3c2","name":"","rules":[{"t":"set","p":"title","pt":"msg","to":"Coucou","tot":"str"},{"t":"set","p":"message","pt":"msg","to":"Long Message","tot":"str"},{"t":"set","p":"short_message","pt":"msg","to":"Short Message","tot":"str"},{"t":"set","p":"dest","pt":"msg","to":"tel_clement;mail_clement","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":1880,"wires":[["7300bcc2.c97c34"]]}]
#Enjoy
