hi, i’m try to create a subflow with a curent_state where i use:
msg.payload.data.entity_id
for the entity_id.
This is working fine if i only have 1 entity_id. but fails if I try to send more id’s.
"Entity could not be found in cache for entity_id: light.light_2244189, light.light_217693, light.light_2254941"
apmillen
(Andy)
2
As far as I know, the current state node can only check a single entity_id
exactly my experience
so what is the solution ?
apmillen
(Andy)
4
Use a current state node for each entity id?
I do not see this as a dynamic solution… hope to find a better one.
apmillen
(Andy)
6
Let us know if you find a better way ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
