Subject: Reolink E1 Two-Way-Audio not working on iPhone via Nginx Proxy Manager (go2rtc)
Hey everyone,
I’m having a problem with two-way audio on my Reolink E1Pro and E1 Outdoor PoE cameras in Frigate (running on Home Assistant).
The Problem
  • PC Access: When I access the Frigate UI on my PC, I have both video and two-way audio (talking to the camera and hearing the return audio) without any issues.
  • iPhone Access (via Nginx Proxy Manager): I can see the video stream, and I can speak into my phone’s microphone and the audio comes out of the camera’s speaker.
  • Missing Return Audio: The major problem is that I hear no return audio (the sound from the camera’s microphone) on my iPhone. The stream is completely silent. The microphone icon is there, but there is no sound coming back.
My Setup
  • Cameras: Reolink E1Pro and Reolink E1 Outdoor PoE.
  • Server: Home Assistant on a server with Nginx Proxy Manager (NPM).
  • Frigate Version: 0.15.2.
  • Access: I access my Home Assistant/Frigate instance from outside my network via my domain name using NPM.
  • Frigate Configuration: My go2rtc streams have both the standard RTSP stream and the webrtc://?ssl stream enabled. I’ve also correctly set the onvif port to 8000 for the Reolink cameras in my frigate.yml file.
  • NPM Configuration:
    • I have a Stream configured in NPM for Port 8555 that forwards to my Home Assistant server’s IP (192.168.178.109) on the same port.
    • Both TCP and UDP forwarding are enabled for this stream.
    • I have deleted the incorrect location /go2rtc/api/webrtc block from my “Advanced” Nginx configuration, as I understand this is for HTTP/HTTPS proxies and not for UDP-based WebRTC streams.
My Question
Despite all these steps, the return audio on my iPhone is not working. The one-way audio (my voice to the camera) seems to be working, which suggests the outgoing connection is fine, but the incoming audio is being blocked or dropped.
Has anyone experienced this specific issue with no return audio on mobile devices via an Nginx Proxy Manager? What could be blocking the incoming UDP audio stream, even with the correct NPM “Stream” and router port forwarding configured? Any help would be greatly appreciated.
here is my config:
mqtt:
  enabled: true
  host: 192.168.178.109
  port: 1883
  topic_prefix: frigate
  client_id: frigate
  user: USER
  password: PW
  stats_interval: 300
database:
  path: /config/frigate.db
detectors:
  coral:
    type: edgetpu
    device: usb
record:
  enabled: true
  retain:
    days: 3
go2rtc:
  media_dir: /media/frigate
  streams:
    UGKueche: # Reolink E1Pro
      - "rtsp://USER:[email protected]:554/h264Preview_01_main"
      - "rtsp://USER:[email protected]:554/h264Preview_01_sub"
      - "rtsp://USER:[email protected]:554/h264Preview_01_main?talk=1"
      - "webrtc://"
    UGKueche-sub:
cameras:
  UGKueche:
    ffmpeg:
#      output_args:
#        record: preset-record-generic-audio-copy
      inputs:
        - path: "rtsp://127.0.0.1:8554/UGKueche"
          input_args: preset-rtsp-restream
          roles:
            - record
            - audio
        - path: "rtsp://127.0.0.1:8554/UGKueche-sub"
          roles:
            - detect
    detect:
      width: 1280
      height: 720
      fps: 10
    objects:
      track:
        - person
        - car
      filters:
        person:
          min_score: 0.4
          min_area: 700
    record:
      enabled: true
    audio:
      enabled: true
      listen:
        - "rtsp://127.0.0.1:8554/UGKueche"
    onvif:
      host: 192.168.178.59
      port: 8000
      user: USER
      password: PW
ui:
  timezone: Europe/Berlin
version: 0.15.2
semantic_search:
  enabled: false
  reindex: false
  model_size: large
frigate is running as add-on in Dell 9020 mini with HAos
do you need more info to help me?
