i got my hands on an ‘industrial standard’ hydrostatic level sensor (pressure sensor) from work that i plan to install in our rainwater tank but i need some help with identifying the wires. There is a data sheet on the manufacturer website but it does not tell me much about the wiring. I plan on using it with the shelly uni so i think i only need 3 (red, blue, white) wires. The sensor has 8 wires.
FLTR:
I think we can safely assume that grey is black. If you know the sensor has been modified I’d be inclined to believe the label on the device rather than the datasheet.
Red to load resistor
Black/grey to +V (though this does seem odd to me, perhaps you should ask about the modifications).
Load resistor to ground.
Measure output across the load resistor.
There’s an equation in the data sheet for calculating the load resistor, it must be less than or equal to:
(V - 15) / 0.02 Ohms.
E.g. for your 19V supply:
(19 - 15) / 0.02 = 200 Ohms.
The closer you get to this value the larger your output voltage swing will be. You are looking at 0.8v to 4v for 4 to 20mA. Which is only a third of the Shelly Uni’s 12V ADC input. So not a good choice.
Id be inclined to use an ESP32 which has a programmable input range.
Yeah, red is +V. We cut the cable before the plastic ‘breather thingy’ and as it turns out only the red and black cables are connected to the green and yellow one’s… Why, i do not know. But now we know we have a 2 wire variant so i think the sticker on the sensor is wrong. Red is +, black is -.
I also ordered a 24v 125mA powersupply. I’ll post the wiring diagram and some pictures when i have the time.
turned out the sensor just won’t work. I bought another one from dfrobot.com and can confirm it works with the shelly uni. I’ll post pictures of the installation as soon as possible.
