Hello!
I’m using substitutions in esphome such as follows:
substitutions:
project: "My reactor"
temp_cutoff: "38"
Is there a way to access the value temp_cutoff in lambda code? id(temp_cutoff).state does not work. Any ideas?
Hello!
substitutions:
temp_cutoff: "38"
Might be easier to use a global variable which can be accessed…
# Example configuration entry
globals:
- id: my_global_int
type: int
restore_value: no
initial_value: '0'
# In an automation
on_press:
then:
- lambda: |-
if (id(my_global_int) > 5) {
// global value is greater than 5
id(my_global_int) += 1;
} else {
id(my_global_int) += 10;
ESP_LOGD(TAG, "Global value is: %d", id(my_global_int));
not pretty, not even sure if you should do it this way but this works:
text_sensor:
# status
lambda: !lambda |-
return to_string("${name}");
as far as i can tell you need to typecast from:
‘const char [14]’ to `‘esphome::optional<std::__cxx11::basic_string >’
which i think it means you either assign the value to a variable of the right type or you typecast it but the substitution needs quotes otherwise i get an error because the to_string method breaks if you have special characters like spaces
