first of all, I’m quite new to this and was suzper surprised when I started my RPI with hassos yesterday and hassio configured by itself!
I decided to use a homematic radiator controller as a start and inspired by the following tweet I ordered my own HmIP-RFUSB: https://twitter.com/pvizeli/status/1056675435508043776 ( HomeMatic IP support on our hass.io add-on is available. Plugin the HmIP-RFUSB and install our add-on and run the local HmIP devices without cloud.)
So, I plugged it in, installed the addon and then - nothing happened. I figured out that I neet to change the default config and disabled using rf and enabled hmip (I guess this makes sense).
After starting the add-on still nothing worked and I see the following error:
Init Hardware Info
java.io.FileNotFoundException: /boot/VERSION (No such file or directory)
at java.base/java.io.FileInputStream.open0(Native Method)
at java.base/java.io.FileInputStream.open(FileInputStream.java:220)
at java.base/java.io.FileInputStream.<init>(FileInputStream.java:158)
at java.base/java.io.FileInputStream.<init>(FileInputStream.java:113)
at de.eq3.lib.util.HardwareInfo.<init>(HardwareInfo.java:22)
at de.eq3.lib.util.HardwareInfo.<clinit>(HardwareInfo.java:10)
at de.eq3.ccu.server.internal.HMServerConfiguration.setDefaults(HMServerConfiguration.java:51)
at de.eq3.ccu.server.internal.HMServerConfiguration.<init>(HMServerConfiguration.java:34)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:488)
at java.base/java.lang.Class.newInstance(Class.java:560)
at de.eq3.lib.util.dynamics.GenericFactory.newInstance(GenericFactory.java:90)
at de.eq3.lib.util.dynamics.GenericFactory.createInstance(GenericFactory.java:26)
at de.eq3.ccu.server.BaseHMServer.setConfig(BaseHMServer.java:78)
at de.eq3.ccu.server.ip.HMIPServer.main(HMIPServer.java:134)
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by io.netty.util.internal.PlatformDependent0$1 (file:/opt/HMServer/HMIPServer.jar) to field java.nio.Buffer.address
WARNING: Please consider reporting this to the maintainers of io.netty.util.internal.PlatformDependent0$1
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Unfortunately I invested a lot of googeling and reading this forum buit I did not understand which step I am missing to make it work.
The documentation says “Set up a HomeMatic hardware layer.” - is this an additional step? What do I need to do here?
After my last post I directly created a snapshot to save the working state. Unfortunately it run only for one week and I got new problems. Also the snapshot doesn’t resolve the problem
What happened during this week? I only installed software-updates for both HASS and the Addon. There were no changes in the config done by me.
I tried to troubleshoot some stuff, but nothing happened, so I completeley reinstalled my Raspberry Pi today, though Homematic still doesn’t want to work
How does the problem look like?
The thermostat doesn’t find the adapter.
When opening the HASS UI the home screen shows the following error:
Error during setup of component homematic
File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 148, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/homematic/__init__.py", line 261, in setup
'ip': socket.gethostbyname(rconfig.get(CONF_HOST)),
socket.gaierror: [Errno -2] Name does not resolve
I can’t get Homematic Addon to start… When I click on start, it seems to start, but when reloading the page, it shows status “not running”. I didn’t change any of my configuration which I showed in the first post, and now the log looks like this:
[DEBUG] Start bootloader ...
[DEBUG] Bootloader running
[DEBUG] Request bootloader version ...
[INFO] SGTIN = 3014f5ac94000416fb5331d4
[INFO] Performing update with firmware file '/firmware/HmIP-RFUSB/hmip_coprocessor_update-2.8.6.eq3' ...
[DEBUG] Start application ...
[DEBUG] Application 'HMIP_TRX_App' running
[DEBUG] Request application version ...
[INFO] Updating coprocessor from version 2.8.4 to version 2.8.6
[INFO] Entering bootloader ...
[INFO] Bootloader version: 1.0.12
[DEBUG] Send update frames ...
[ERROR] No update performed.
[INFO] Exiting update tool.
I really have no idea what to do now… @pvizeli you?
@schneeschipp any updates? I connected my HmIP-RFUSB following the updated instructions of @pvizeli. I also managed to learn my HmIP-eTRV-B1 using Homematic Manager but the valve does not appear in Home Assistant .
Instead, the log of the OCCU plugin contains the following exception:
Init Hardware Info
Dec 07, 2018 8:17:07 PM io.vertx.core.impl.BlockedThreadChecker
WARNING: Thread Thread[vert.x-eventloop-thread-0,5,main] has been blocked for 2595 ms, time limit is 2000
java.io.IOException: No such file or directory
at java.base/java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.base/java.io.File.createNewFile(File.java:1024)
at de.eq3.ccu.server.ip.HMIPServer.initialize(HMIPServer.java:206)
at de.eq3.ccu.server.ip.HMIPServer.<init>(HMIPServer.java:41)
at de.eq3.ccu.server.ip.HMIPServer$2.run(HMIPServer.java:147)
at java.base/java.lang.Thread.run(Thread.java:844)
for me it’s the same Problem as with @jaqPi but my log looks a bit different. HmIP-RFUSB with Home Assistant 0.83.2 on HassOS 1.13 (maybe I’ll update to .3 within the next days to see if something changes).
Init Hardware Info
@jaqPi, @semaphor,
I never saw these errors, only the ones I posted earlier.
In my case I made every available update und hoped for resolution. Until last Sunday there was none and I sold my HmIP-USB-Stick and changed from HA to the HomeMatic Zentrale. Since then it works without any problem.
Good news! Since I upgraded to Hass 0.84.X and HomeMatic OCCU 8.0, I am able to pair the HmIP-eTRV-B1 with Home Assisant / the USB stick.
Unfortunately, sometimes the thermostat loses its connection. I haven’t been able to figure out, why this happens or what makes the thermostat lose its connection…
For the record: after using an external power supply for my Sonoff bridge instead of powering both the Sonoff and the HmIP-RFUSB directly with the rpi, it works like a charm for the last weeks
