All of a sudden I get these errors when I start HA:
2017-08-27 14:11:13 ERROR (MainThread) [homeassistant.setup] Error during setup of component mqtt
File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 191, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File "/usr/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 387, in async_setup
success = yield from hass.data[DATA_MQTT].async_connect()
File "/usr/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 497, in async_connect
self._mqttc.connect, self.broker, self.port, self.keepalive)
File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/paho/mqtt/client.py", line 760, in connect
return self.reconnect()
File "/usr/lib/python3.6/site-packages/paho/mqtt/client.py", line 919, in reconnect
sock.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 1061, in do_handshake
self._sslobj.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 683, in do_handshake
ssl.SSLEOFError: EOF occurred in violation of protocol (_ssl.c:749)
2017-08-27 14:11:22 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of device_tracker.owntracks. Setup failed for dependencies: mqtt
I have not changed anything, and Zanzito connects fine on the phone.
mqtt:
broker: xx.cloudmqtt.com
port: 27297
username:
password:
In cloudmqtt’s log, I see a lot of these however:
1503834564: Client connection from xxx.xxx.xx.xx denied access by tcpd.
What’s the problem here? Is it on cloudmqtt’s end?
Edit:
After a few restarts of cloudmqtt’s mosquitto, the problem went away.
Hopefully it’s solved now.
