all of the sudden my HA has been acting weird.
I can’t send notifications through iOS, IFTTT won’t connect, map tracker won’t scan properly.
All this without a config change.
this is the error I get with those platforms (but the component part changes per components obviously):
Log Details (ERROR)
Fri Sep 21 2018 00:00:05 GMT+0200 (CEST)
Error communicating with IFTTT
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 171, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 56, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.6/socket.py", line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 849, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 314, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 180, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x70fb5850>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 445, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='maker.ifttt.com', port=443): Max retries exceeded with url: /trigger/batterij_tracken/with/key/xxxxxxx/ (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x70fb5850>: Failed to establish a new connection: [Errno -3] Try again',))
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/ifttt.py", line 67, in trigger_service
pyfttt.send_event(key, event, value1, value2, value3)
File "/usr/local/lib/python3.6/site-packages/pyfttt/sending.py", line 12, in send_event
return requests.post(url, data=payload)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 112, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 512, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 622, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 513, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='maker.ifttt.com', port=443): Max retries exceeded with url: /trigger/batterij_tracken/with/key/xxxxxxx/ (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x70fb5850>: Failed to establish a new connection: [Errno -3] Try again',))
I saw multiple people who had this problem with a lot of other components which makes me think its a HA problem and not a component specific problem. I believe it has something to do with making a connection to outside servers. Nobody ever talked about fixing the problem though.
I’m trying to avoid wiping my sd card and start all over so any tips are welcome.
