After 2024.7.0 I started to have the database problems as described in the github defect.
They went away after installing 2024.7.2, so it works now OK.
However, since the update, I have my charger showing negative energy values.
The integration for the energy meter (go-e MQTT integration) was not updated, but the HA core was.
Does anyone else have this issue?
I got the same problem, did you find a solution ?
Yes - switch the energy device from Charged energy to Total energy (eto sensor). That sensor is also already stored and will just smoothly replace the wrong one
Thanks my man !
