I have about a dozen Jasco/GE light switches connected to a Aeotec USB Z-Stick on a Raspberry Pi 3b+. For a while, they were working great with Homeassistant. After several breaking changes, I just decided to completely reinstall HA and do things the “right way” using the ZWave option on the configuration menu.
I’ve ran into an issue where I can’t add more than 7 devices. Things that were well in range before now cannot be added.
When I click Add Node, journalctl reports:
Apr 24 01:55:29 pibox hass[1148]: 2020-04-24 01:55:29 INFO (SyncWorker_9) [homeassistant.components.zwave] Z-Wave add_node have been initialized
Apr 24 02:02:02 pibox hass[1148]: 2020-04-24 02:02:02 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.1594965840] Connection closed by client
Apr 24 02:03:19 pibox hass[1148]: 2020-04-24 02:03:19 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error in data received
Apr 24 02:03:19 pibox hass[1148]: Traceback (most recent call last):
Apr 24 02:03:19 pibox hass[1148]: File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 526, in data_received
Apr 24 02:03:19 pibox hass[1148]: ssldata, appdata = self._sslpipe.feed_ssldata(data)
Apr 24 02:03:19 pibox hass[1148]: File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 207, in feed_ssldata
Apr 24 02:03:19 pibox hass[1148]: self._sslobj.unwrap()
Apr 24 02:03:19 pibox hass[1148]: File "/usr/local/lib/python3.7/ssl.py", line 767, in unwrap
Apr 24 02:03:19 pibox hass[1148]: return self._sslobj.shutdown()
Apr 24 02:03:19 pibox hass[1148]: ssl.SSLError: [SSL: KRB5_S_INIT] application data after close notify (_ssl.c:2609)
Apr 24 02:03:19 pibox hass[1148]: 2020-04-24 02:03:19 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.1594612784] Connection closed by client
And OZW_Log reports:
2020-04-24 01:55:29.021 Detail, Queuing (Controller) Add Device
2020-04-24 01:55:29.022 Info, Add Device
2020-04-24 01:55:29.022 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x3a, 0x4b
2020-04-24 01:55:29.022 Detail, Notification: ControllerCommand - Starting
2020-04-24 01:55:29.023 Detail,
2020-04-24 01:55:29.023 Info, contrlr, Sending (Command) message (Callback ID=0x3a, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x3a, 0x4b
2020-04-24 01:55:29.027 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x3a, 0x01, 0x00, 0x00, 0x89
2020-04-24 01:55:29.027 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-04-24 01:55:29.028 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2020-04-24 01:55:29.028 Detail, Node001, Expected callbackId was received
2020-04-24 01:55:29.028 Detail, Node001, Expected reply was received
2020-04-24 01:55:29.028 Detail, Node001, Message transaction complete
2020-04-24 01:55:29.028 Detail, contrlr, Removing current message
2020-04-24 01:55:29.028 Detail, Notification: ControllerCommand - Waiting
2020-04-24 01:55:29.031 Info, WriteNextMsg Controller nothing to do
And nothing. This timeout actually puts either homeassistant or OpenZWave into this blocked state. If I try to turn things on and off, I can see OpenZWave keep sending out commands, but nothing actually happens to the lights.
2020-04-24 02:05:55.869 Info, Node007, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - False
2020-04-24 02:05:55.869 Info, Node007, SwitchBinary::Set - Setting node 7 to Off
2020-04-24 02:05:55.869 Detail, Node007, Queuing (Send) SwitchBinaryCmd_Set (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x25, 0x01, 0x00, 0x25, 0x3d, 0xde
2020-04-24 02:05:55.869 Detail, Node007, Queuing (Send) SwitchBinaryCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x25, 0x02, 0x25, 0x3e, 0xdc
Any idea what’s going on? This is quite frustrating because everything was working fine for years, so I doubt it’s a signal strength issue.
Raspbian Buster
Raspberry Pi 3b+
Python 3.7.3
HA running in a virtual environment
