Logger: somecomfort
Source: /usr/local/lib/python3.10/site-packages/somecomfort/client.py:445
First occurred: February 15, 2023 at 8:58:13 AM (351 occurrences)
Last logged: 10:08:41 AM
API Rate Limited.
Note that this has happened 351 times since February15. I’m running HA 2023.1.7. I’ve been running the Honeywell integration without error for years.
I have seen that too in 2023.1.7.
I just upgraded to 2023.2.5 and I’m seeing other errors.
Logger: homeassistant.helpers.entity
Source: components/honeywell/climate.py:416
First occurred: 1:47:10 PM (3 occurrences)
Last logged: 1:47:10 PM
Update for climate.home_ac fails
Update for climate.home_heat fails
Update for climate.shore fails
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 1154, in _create_direct_connection
hosts = await asyncio.shield(host_resolved)
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 880, in _resolve_host
addrs = await self._resolver.resolve(host, port, family=self._family)
File "/usr/local/lib/python3.10/site-packages/aiohttp/resolver.py", line 33, in resolve
infos = await self._loop.getaddrinfo(
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 860, in getaddrinfo
return await self.run_in_executor(
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.10/socket.py", line 955, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 548, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 754, in async_device_update
await task
File "/usr/src/homeassistant/homeassistant/components/honeywell/climate.py", line 416, in async_update
await self._data.client.login()
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 535, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 542, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 907, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 1166, in _create_direct_connection
raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host www.mytotalconnectcomfort.com:443 ssl:default [Try again]
For the record, this stopped happening shortly after I posted. It’s only been a few hours, so it’s too soon to know if this was a one-time anomaly.
The Honeywell integration has been stable for a while now. I hope this isn’t a new problem introduced by a recent update. It could also be something on the Honeywell server end. I’ll keep monitoring.
Anyone else with the Honeywell (US) integration, please feel free to post your experience, good or bad.
