Suddenly HA/Hassio stoped working... Looks like add-ons still do. Can anyone check my LOG?
Hi Guys,
So i was just looking around in my frontend and and noticed that when i walked in the kitchen my lights didnt turn on. So i reloaded the app and my frontend and i got a page not found error… When I look at my log trough samba i get this big bulk of tekst i cant make logic out off… I stil can acces my add-ons trough there own URL (traccar, Unifi Controller).
I tried to reboot the host, delete the DB. Any other thing i can try?
2020-01-26 17:18:07 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-26 17:18:07 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for mind which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-26 17:18:08 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds.
2020-01-26 17:18:08 INFO (MainThread) [homeassistant.setup] Setting up http
2020-01-26 17:18:08 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2020-01-26 17:18:08 INFO (MainThread) [homeassistant.setup] Setting up system_log
2020-01-26 17:18:08 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2020-01-26 17:18:08 INFO (MainThread) [homeassistant.setup] Setting up recorder
2020-01-26 17:18:09 INFO (MainThread) [homeassistant.setup] Setting up webhook
2020-01-26 17:18:09 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2020-01-26 17:18:09 INFO (SyncWorker_9) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa
2020-01-26 17:18:09 INFO (SyncWorker_19) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant
2020-01-26 17:18:09 INFO (SyncWorker_3) [homeassistant.loader] Loaded camera from homeassistant.components.camera
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up cloud
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 3.1 seconds.
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.0 seconds.
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up zone
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.0 seconds.
2020-01-26 17:18:12 INFO (SyncWorker_7) [homeassistant.loader] Loaded manual from homeassistant.components.manual
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up scene
2020-01-26 17:18:12 INFO (SyncWorker_15) [homeassistant.loader] Loaded ping from homeassistant.components.ping
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up updater
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up wake_on_lan
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setup of domain wake_on_lan took 0.0 seconds.
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up input_select
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds.
2020-01-26 17:18:12 INFO (SyncWorker_10) [homeassistant.loader] Loaded kodi from homeassistant.components.kodi
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2020-01-26 17:18:12 INFO (SyncWorker_13) [homeassistant.loader] Loaded darksky from homeassistant.components.darksky
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up group
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up sun
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds.
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up homekit
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.setup] Setting up mind
2020-01-26 17:18:12 INFO (SyncWorker_9) [homeassistant.loader] Loaded time_date from homeassistant.components.time_date
2020-01-26 17:18:12 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2020-01-26 17:18:13 INFO (MainThread) [homeassistant.setup] Setting up alarm_control_panel
2020-01-26 17:18:13 INFO (MainThread) [homeassistant.setup] Setting up person
2020-01-26 17:18:13 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 1.2 seconds.
2020-01-26 17:18:13 INFO (SyncWorker_14) [homeassistant.loader] Loaded html5 from homeassistant.components.html5
2020-01-26 17:18:13 INFO (MainThread) [homeassistant.setup] Setting up weather
2020-01-26 17:18:14 INFO (SyncWorker_17) [homeassistant.loader] Loaded spotify from homeassistant.components.spotify
2020-01-26 17:18:14 INFO (SyncWorker_2) [homeassistant.loader] Loaded version from homeassistant.components.version
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setting up deconz
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setup of domain deconz took 0.0 seconds.
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setting up system_health
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.components.alarm_control_panel] Setting up alarm_control_panel.manual
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setting up shopping_list
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setting up config
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds.
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setting up api
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setting up history
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.components.weather] Setting up weather.darksky
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setting up sonos
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setup of domain sonos took 0.0 seconds.
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setup of domain homekit took 1.9 seconds.
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setup of domain mind took 1.9 seconds.
2020-01-26 17:18:14 INFO (SyncWorker_12) [homeassistant.loader] Loaded moon from homeassistant.components.moon
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setting up auth
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.helpers.storage] Migrating person storage from 1 to 2
2020-01-26 17:18:14 INFO (MainThread) [homeassistant.setup] Setup of domain shopping_list took 0.7 seconds.
2020-01-26 17:18:15 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.7 seconds.
2020-01-26 17:18:15 INFO (MainThread) [homeassistant.setup] Setting up telegram_bot
2020-01-26 17:18:15 INFO (MainThread) [homeassistant.components.telegram_bot] Setting up telegram_bot.polling
2020-01-26 17:18:15 INFO (MainThread) [homeassistant.setup] Setup of domain telegram_bot took 0.0 seconds.
2020-01-26 17:18:15 INFO (SyncWorker_1) [homeassistant.loader] Loaded configurator from homeassistant.components.configurator
2020-01-26 17:18:15 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2020-01-26 17:18:15 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2020-01-26 17:18:15 INFO (MainThread) [homeassistant.setup] Setup of domain config took 1.0 seconds.
2020-01-26 17:18:15 INFO (MainThread) [homeassistant.setup] Setup of domain group took 2.9 seconds.
2020-01-26 17:18:15 INFO (SyncWorker_0) [homeassistant.loader] Loaded filesize from homeassistant.components.filesize
2020-01-26 17:18:15 INFO (SyncWorker_10) [homeassistant.loader] Loaded discord from homeassistant.components.discord
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.setup] Setting up esphome
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.setup] Setup of domain esphome took 0.0 seconds.
2020-01-26 17:18:16 INFO (SyncWorker_13) [homeassistant.loader] Loaded systemmonitor from homeassistant.components.systemmonitor
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.setup] Setting up switch
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.setup] Setting up script
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.setup] Setting up plant
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.components.plant] Added plant plant_Alocasia_ol
2020-01-26 17:18:16 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for iphonedetect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.setup] Setting up light
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2020-01-26 17:18:16 INFO (SyncWorker_19) [homeassistant.loader] Loaded traccar from homeassistant.components.traccar
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.setup] Setting up media_player
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.setup] Setting up notify
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.components.switch] Setting up switch.wake_on_lan
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.components.light] Setting up light.group
2020-01-26 17:18:16 INFO (MainThread) [homeassistant.components.notify] Setting up notify.discord
2020-01-26 17:18:17 INFO (SyncWorker_6) [homeassistant.loader] Loaded command_line from homeassistant.components.command_line
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setting up kodi
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setup of domain kodi took 0.0 seconds.
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setting up cast
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setup of domain cast took 0.0 seconds.
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 4.7 seconds.
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.9 seconds.
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setup of domain plant took 0.9 seconds.
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setting up automation
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setting up configurator
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setup of domain configurator took 0.0 seconds.
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.kodi
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.components.notify] Setting up notify.kodi
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 5.0 seconds.
2020-01-26 17:18:17 INFO (SyncWorker_3) [homeassistant.loader] Loaded dsmr from homeassistant.components.dsmr
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2020-01-26 17:18:17 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for attributes which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-26 17:18:17 INFO (SyncWorker_10) [homeassistant.loader] Loaded template from homeassistant.components.template
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setup of domain alarm_control_panel took 4.5 seconds.
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.components.notify] Setting up notify.html5
2020-01-26 17:18:17 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 4.1 seconds.
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.setup] Setup of domain person took 4.6 seconds.
2020-01-26 17:18:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for composite which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
2020-01-26 17:18:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for p2000 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-26 17:18:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for trakt which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.setup] Setting up sensor
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 1.2 seconds.
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.time_date
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.template
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.moon
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.version
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.filesize
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.p2000
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.systemmonitor
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.command_line
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.dsmr
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.trakt
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.attributes
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.spotify
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.setup] Setting up camera
2020-01-26 17:18:18 INFO (MainThread) [homeassistant.components.scene] Setting up scene.deconz
2020-01-26 17:18:19 INFO (MainThread) [custom_components.p2000.sensor] Last datestamp read 2020-01-26 17:16:43
2020-01-26 17:18:19 INFO (MainThread) [custom_components.attributes.sensor] Starting attribute sensor
2020-01-26 17:18:19 INFO (MainThread) [custom_components.attributes.sensor] Adding attribute: battery of entity: device_tracker.golf
2020-01-26 17:18:19 INFO (MainThread) [custom_components.attributes.sensor] Adding attribute: battery of entity: device_tracker.slk
2020-01-26 17:18:19 INFO (MainThread) [custom_components.attributes.sensor] Adding attribute: battery of entity: device_tracker.mx_5
2020-01-26 17:18:19 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 1.6 seconds.
2020-01-26 17:18:19 INFO (SyncWorker_10) [homeassistant.loader] Loaded climate from homeassistant.components.climate
2020-01-26 17:18:19 INFO (SyncWorker_7) [homeassistant.loader] Loaded cover from homeassistant.components.cover
EDIT: Found solution. It was the custom component - Trakt sensor.
was it the trakt sensor?
Yes. Have been running problem free now and no error’s.
Sorry, i was making a bad joke because the system screwed up and posted 4 of the same comment
