I’m running Supervised over Debian on a gen10 i5 NUC.
My CPU usage has been steady at around 2% for the last year up until a couple of weeks ago when is suddenly rose to about 15% or so, and after restarting Core I was right back at 2%. This has happened 2-3 times a week since then. Since today, updating HA and trying to fix a couple of “repairs”(systemd journal and connectivity check) restarting Core doesn’t have an effect anymore, the CPU load stays around 15%.
I tried to restore a snapshot from before this issue first was introduced without any difference, and I have done anything special around the time the issue first was observed - the most “dramatic” thing I can recall is updating the underlying OS.
The logger is set to DEBUG for Homeassistant core. I can’t find anything in the logs. When looking at the graph attached above it seems like the CPU started to climb around 13:05 and reached its destination around 13:15.
TOP gives me 118,3 %CPU:
8795 root 20 0 1542736 418260 57920 R 118,3 2,6 19:26.27 python3
So, I need help.
Any idea where I should start digging?
