My RPi4 with a Supervised Install just got very sluggish so I looked in Portainer and saw that CPU Usage of the InfluxDB Container was North of 150%.
I updated to the latest add-on version but it didn’t change a thing.
From what I can see with htop there are still multiple influxdb processes running that eat up way more CPU% than they should.
These are the log entries if somebody understands what they mean and can give me any direction how I can fix this - other than just turning the add-on off permanently:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.,
[s6-init] ensuring user provided files have correct perms...exited 0.,
[fix-attrs.d] applying ownership & permissions fixes...,
[fix-attrs.d] done.,
[cont-init.d] executing container initialization scripts...,
[cont-init.d] 00-banner.sh: executing... ,
Add-on: InfluxDB,
Scalable datastore for metrics, events, and real-time analytics,
Add-on version: 3.7.5,
You are running the latest version of this add-on.,
System: Raspbian GNU/Linux 10 (buster) (armv7 / raspberrypi4),
Home Assistant Core: 0.114.4,
Home Assistant Supervisor: 235,
Please, share the above information when looking for help,
or support in, e.g., GitHub, forums or the Discord chat.,
[cont-init.d] 00-banner.sh: exited 0.,
[cont-init.d] 01-log-level.sh: executing... ,
[cont-init.d] 01-log-level.sh: exited 0.,
[cont-init.d] create-users.sh: executing... ,
[cont-init.d] create-users.sh: exited 0.,
[cont-init.d] influxdb.sh: executing... ,
[cont-init.d] influxdb.sh: exited 0.,
[cont-init.d] kapacitor.sh: executing... ,
[cont-init.d] kapacitor.sh: exited 0.,
[cont-init.d] nginx.sh: executing... ,
[cont-init.d] nginx.sh: exited 0.,
[cont-init.d] done.,
[services.d] starting services,
[services.d] done.,
[18:51:56] INFO: Chronograf is waiting until InfluxDB is available...,
[18:51:56] INFO: Kapacitor is waiting until InfluxDB is available...,
[18:51:56] INFO: Starting the InfluxDB...,
[httpd] 127.0.0.1 - chronograf [28/Aug/2020:18:52:21 -0700] "GET /ping HTTP/1.1" 204 0 "-" "InfluxDBShell/1.8.2" 473cb933-e99a-11ea-8001-0242ac1e2102 254,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:52:21 -0700] "GET /ping HTTP/1.1" 204 0 "-" "InfluxDBShell/1.8.2" 473ebbbb-e99a-11ea-8003-0242ac1e2102 60,
[httpd] 127.0.0.1 - chronograf [28/Aug/2020:18:52:21 -0700] "POST /query?chunked=true&db=&epoch=ns&q=SHOW+DATABASES HTTP/1.1" 200 121 "-" "InfluxDBShell/1.8.2" 473cfed1-e99a-11ea-8002-0242ac1e2102 156245,
[18:52:21] INFO: Starting Chronograf...,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:52:21 -0700] "POST /query?chunked=true&db=&epoch=ns&q=SHOW+DATABASES HTTP/1.1" 200 121 "-" "InfluxDBShell/1.8.2" 473ee6bd-e99a-11ea-8004-0242ac1e2102 166259,
[18:52:21] INFO: Starting the Kapacitor,
2020/08/28 18:52:22 Using configuration at: /etc/kapacitor/kapacitor.conf,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:52:22 -0700] "GET /ping HTTP/1.1" 204 0 "-" "KapacitorInfluxDBClient" 478da706-e99a-11ea-8005-0242ac1e2102 82,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:52:22 -0700] "POST /query?db=&q=SHOW+DATABASES HTTP/1.1" 200 121 "-" "KapacitorInfluxDBClient" 478e0f96-e99a-11ea-8006-0242ac1e2102 3912,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:52:22 -0700] "POST /query?db=&q=SHOW+RETENTION+POLICIES+ON+_internal HTTP/1.1" 200 153 "-" "KapacitorInfluxDBClient" 478f05a1-e99a-11ea-8007-0242ac1e2102 2559,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:52:22 -0700] "POST /query?db=&q=SHOW+RETENTION+POLICIES+ON+homeassistant HTTP/1.1" 200 149 "-" "KapacitorInfluxDBClient" 478f9d6c-e99a-11ea-8008-0242ac1e2102 2950,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:52:22 -0700] "POST /query?db=&q=SHOW+SUBSCRIPTIONS HTTP/1.1" 200 225 "-" "KapacitorInfluxDBClient" 479037d8-e99a-11ea-8009-0242ac1e2102 2178,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:52:24 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 48cfd7ee-e99a-11ea-800a-0242ac1e2102 202373,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:52:24 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 48fb5b45-e99a-11ea-800b-0242ac1e2102 17467,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:52:24 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 4905d252-e99a-11ea-800c-0242ac1e2102 14726,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:52:24 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 490e1ede-e99a-11ea-800d-0242ac1e2102 79973,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:52:24 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 4920820f-e99a-11ea-800e-0242ac1e2102 12535,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:52:24 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 49288188-e99a-11ea-800f-0242ac1e2102 16162,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:52:25 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 4930fc66-e99a-11ea-8010-0242ac1e2102 11626,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:52:27 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 4a9845f9-e99a-11ea-8011-0242ac1e2102 30654,
time="2020-08-28T18:52:40-07:00" level=info msg="Reporting usage stats" component=usage freq=24h reporting_addr="https://usage.influxdata.com" stats="os,arch,version,cluster_id,uptime",
time="2020-08-28T18:52:40-07:00" level=info msg="Serving chronograf at http://127.0.0.1:8889" component=server,
[18:52:41] INFO: Starting NGinx...,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:52:45 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 55a83e75-e99a-11ea-8012-0242ac1e2102 15731,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:52:58 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 5d1165f1-e99a-11ea-8013-0242ac1e2102 10715,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:53:02 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 5f77a1c8-e99a-11ea-8014-0242ac1e2102 8835,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:53:14 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 66989351-e99a-11ea-8015-0242ac1e2102 10105,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:53:16 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 67dbc729-e99a-11ea-8016-0242ac1e2102 13228,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:53:22 -0700] "GET /ping HTTP/1.1" 204 0 "-" "KapacitorInfluxDBClient" 6b504b75-e99a-11ea-8017-0242ac1e2102 74,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:53:22 -0700] "POST /query?db=&q=SHOW+DATABASES HTTP/1.1" 200 121 "-" "KapacitorInfluxDBClient" 6b5079bc-e99a-11ea-8018-0242ac1e2102 2760,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:53:22 -0700] "POST /query?db=&q=SHOW+RETENTION+POLICIES+ON+_internal HTTP/1.1" 200 153 "-" "KapacitorInfluxDBClient" 6b511a5d-e99a-11ea-8019-0242ac1e2102 2388,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:53:22 -0700] "POST /query?db=&q=SHOW+RETENTION+POLICIES+ON+homeassistant HTTP/1.1" 200 149 "-" "KapacitorInfluxDBClient" 6b51a8fa-e99a-11ea-801a-0242ac1e2102 1217,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:53:22 -0700] "POST /query?db=&q=SHOW+SUBSCRIPTIONS HTTP/1.1" 200 225 "-" "KapacitorInfluxDBClient" 6b522dd6-e99a-11ea-801b-0242ac1e2102 1342,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:53:28 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 6ef5cc75-e99a-11ea-801c-0242ac1e2102 30968,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:53:30 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 7008a3b4-e99a-11ea-801d-0242ac1e2102 7636,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:53:32 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 715ce12c-e99a-11ea-801e-0242ac1e2102 5578,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:53:34 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 729085ea-e99a-11ea-801f-0242ac1e2102 7990,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:53:39 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 754e8660-e99a-11ea-8020-0242ac1e2102 30511,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:53:41 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 76845ff4-e99a-11ea-8021-0242ac1e2102 8873,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:53:53 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 7daa6ebc-e99a-11ea-8022-0242ac1e2102 23113,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:54:05 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 84ceff83-e99a-11ea-8023-0242ac1e2102 119911,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:54:09 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 87319386-e99a-11ea-8024-0242ac1e2102 6694,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:54:11 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 8865ce8d-e99a-11ea-8025-0242ac1e2102 4810,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:54:15 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 8ac9b859-e99a-11ea-8026-0242ac1e2102 4796,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:54:21 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 8e527933-e99a-11ea-8027-0242ac1e2102 4258,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:54:22 -0700] "GET /ping HTTP/1.1" 204 0 "-" "KapacitorInfluxDBClient" 8f138722-e99a-11ea-8028-0242ac1e2102 489,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:54:22 -0700] "POST /query?db=&q=SHOW+DATABASES HTTP/1.1" 200 121 "-" "KapacitorInfluxDBClient" 8f13d88e-e99a-11ea-8029-0242ac1e2102 1725,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:54:22 -0700] "POST /query?db=&q=SHOW+RETENTION+POLICIES+ON+_internal HTTP/1.1" 200 153 "-" "KapacitorInfluxDBClient" 8f14545a-e99a-11ea-802a-0242ac1e2102 1681,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:54:22 -0700] "POST /query?db=&q=SHOW+RETENTION+POLICIES+ON+homeassistant HTTP/1.1" 200 149 "-" "KapacitorInfluxDBClient" 8f14cdcd-e99a-11ea-802b-0242ac1e2102 1101,
[httpd] 127.0.0.1 - kapacitor [28/Aug/2020:18:54:22 -0700] "POST /query?db=&q=SHOW+SUBSCRIPTIONS HTTP/1.1" 200 225 "-" "KapacitorInfluxDBClient" 8f1545cd-e99a-11ea-802c-0242ac1e2102 12760,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:54:28 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 92a5ff8c-e99a-11ea-802d-0242ac1e2102 10691,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:54:39 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 99237b6b-e99a-11ea-802e-0242ac1e2102 190865,
[httpd] 172.30.32.1 - homeassistant [28/Aug/2020:18:54:45 -0700] "POST /write?db=homeassistant HTTP/1.1" 204 0 "-" "python-requests/2.24.0" 9cbb0139-e99a-11ea-802f-0242ac1e2102 4689,
