Hi
I have hass.io installed on standalone intel nuc running ubuntu desktop. Has been working fine using mqtt hass.io addon broker. Suddenly the mqtt hass.io is no longer working and gives the following error:
1541444743: Opening ipv4 listen socket on port 1883.
1541444743: Error: Address in use
I have not changed anything in my setup, just overnight it decided to stop working.
This is my configuration for mqtt broker addon:
"logins": [
"username": "mike",
"password": "xxxxxxxxx"
"anonymous": false,
"customize": {
"active": true,
"folder": "mosquitto"
"certfile": "fullchain.pem",
"keyfile": "privkey.pem",
"plain": false,
"plain_websockets": false,
"ssl": true,
"ssl_websockets": false
and
Container : Host
1883/tcp : 1883
1884/tcp : 1884
8883/tcp : 8883
8884/tcp : 8884
This is my configuration.yaml
mqtt:
broker: 192.168.1.50
username: !secret mqtt_login
password: !secret mqtt_password
discovery: true
birth_message:
topic: 'hass/status'
payload: 'online'
will_message:
payload: 'offline'
If i use ssh and type “lsof -i TCP:1883” i get the following output
root@nuc-server:~# lsof -i TCP:1883
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
docker-pr 8885 root 4u IPv6 24371153 0t0 TCP *:1883 (LISTEN)
root@nuc-server:~# docker container ls
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
4c3f3ea34ffd homeassistant/intel-nuc-homeassistant "/bin/entry.sh pytho…" 10 minutes ago Up 10 minutes homeassistant
d28fdfdf72ad homeassistant/amd64-addon-samba "/run.sh" 12 hours ago Up 12 hours addon_core_samba
f1cc4d09375e homeassistant/amd64-addon-mosquitto "/run.sh" 12 hours ago Up 12 hours 0.0.0.0:1883-1884->1883-1884/tcp, 0.0.0.0:8883-8884->8883-8884/tcp addon_core_mosquitto
912f0fd86b93 homeassistant/amd64-hassio-supervisor "python3 -m hassio" 12 hours ago Up 12 hours hassio_supervisor
977951429a76 ottowinter/esphomeyaml-hassio-amd64 "esphomeyaml /config…" 47 hours ago Up 20 hours 0.0.0.0:6052-6053->6052-6053/tcp addon_7bce6681_esphomeyaml
5c449a89476d homeassistant/amd64-addon-ssh "/run.sh" 47 hours ago Up 20 hours 0.0.0.0:22->22/tcp addon_core_ssh
af96552f1933 homeassistant/amd64-addon-duckdns "/run.sh" 47 hours ago Up 20 hours addon_core_duckdns
d1864fafb47d portainer/portainer "/portainer" 4 weeks ago Up 20 hours 0.0.0.0:9000->9000/tcp portainer
Can anyone tell me what I can do to get it going?
I have tried the following command:
root@nuc-server:~# sudo systemctl stop mosquitto.service
Failed to stop mosquitto.service: Unit mosquitto.service not loaded.
root@nuc-server:~# systemctl status mosquitto.service
Unit mosquitto.service could not be found.
