Suddenly Problems with Zoneminder
I went to .65.5 a few days ago, with no problem. Restarted hassio today and it came up and said invalid zm config.
Here is my config
zoneminder:
host: [zm ip]
username: [user]
password: [pass]
ssl: false
path_zms: /zm/cgi-bin/nph-zms
path: /zm/
I can login to ip/zm just fine. I am running internal zoneminder only on port 80 , path_zms is verified defautl straight from the options>> path in ZM.
2018-03-18 13:02:27 ERROR (SyncWorker_3) [homeassistant.components.zoneminder] Connection error logging into ZoneMinder
this is in the log, it would indicate I can login. although the users name and pass for ZM is used only by ZM and I see in the ZM log that that users has successfully logged in when hassio starts up
