While I know the Android battery usage isn’t the perfect metric, I’m using to seeing the HA app around 1%. Its now at 10% and my battery is very clearly being drained. Any ideas what it might be?
not seeing anything sticking out in the logs, BTW i would delete the post, those logs may contain URLs you may not want to expose.
We do have a troubleshooting step you can look at https://companion.home-assistant.io/docs/troubleshooting/faqs/#android-app-battery-drain if that doesnt work check your data usage as you may be impacted by https://github.com/home-assistant/android/issues/979 whch can be caused by anything that streams on the frontend.
Oh! Deleted logs. Thanks for the heads up.
