Suffering horrible lags and timing issues updating 0.98 to 0.98.1
havent found the reason yet, but my instance has become practically unusable after todays update to 0.98.1.
anyone else seeing this?
made sure the only thing changed (documented) between the 2 versions relevant for my instance are the markdown templates, and updated these accordingly…
and, as always, Hue signals by being unreachable:
2019-08-30 21:42:25 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:42:54 ERROR (MainThread) [homeassistant.components.hue.light] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:43:21 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:44:05 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:45:05 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:45:29 DEBUG (MainThread) [pyhaversion] Version: 0.98.1
2019-08-30 21:45:29 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'Local'}
2019-08-30 21:45:54 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:46:38 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:47:21 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:48:13 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:49:00 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:50:02 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:50:42 ERROR (MainThread) [homeassistant.components.hue.light] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:50:52 DEBUG (MainThread) [pyhaversion] Version: 0.98.1
2019-08-30 21:50:52 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'Local'}
2019-08-30 21:51:30 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:52:15 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:52:56 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:53:37 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:54:23 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:55:07 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:55:47 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Unable to reach bridge 192.168.1.212 ()
2019-08-30 21:56:14 DEBUG (MainThread) [pyhaversion] Version: 0.98.1
update
found that this is now also filling the log:
2019-08-31 11:00:59 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1855956784] Client exceeded max pending messages [2]: 512
2019-08-31 11:02:51 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1850619568] Client exceeded max pending messages [2]: 512
2019-08-31 11:04:16 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1850222320] Client exceeded max pending messages [2]: 512
after an initial:
2019-08-31 12:52:02 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.1835753776] Disconnected: Did not receive auth message within 10 seconds
@Santobert could it be the new binary_sensor.updater causes this? If set logger to info, but other than above I dont see further loggings. Cant test it, because there’s no way to disable the new binary_sensor afaik?
I don’t think that the updater component is causing this. The errors came from the websocket_api, so I think that the connection between frontend and backend is broken. But I’m not an expert for this.
You can disable the updater component by disabling default_config:
thanks!
I don’t have default config enabled on this instance though…and still see the sensor?
-edit
O wait, nevermind about default config: , I do use updater: which does the sensor of course.
Ok, will search for other possible causes. Thanks for chiming in!
