Suggestion: correction instruction on template attributes custom ui
@andrey
concerning: https://github.com/andrey-git/home-assistant-custom-ui#template-attributes.
Been trying to get this to work, but the given example won’t do it.
templates:
        state: if state === 'on' return 'Active'; else return state;
just gives an empty space.
found this to be of effect:
  templates:
    state: if (state === 'home') return 'Active'; else return 'Alert!';
If correct for other instances, you might want to correct the instructions.
Wonderful job btw, im enjoying it better and more every single modification it enables.
Cheers,
Marius
I fixed the example. Thanks!
hate to bother you on this again, but could it be the latest update of custom ui broke this:
below customization worked fine before, as mentioned earlier, but now renders this again, please have a look:
43
device_tracker.iungo:
  templates:
device_tracker.timecapsule:
  templates:
device_tracker.solaredge:
  templates:
device_tracker.hassio:
  templates:
device_tracker.asus_router:
  templates:
device_tracker.hvbdiskstation:
  templates:
device_tracker.ikea_tradfri_hub:
  templates:
There was a bug in 20171214 which was fixed in 20171215
