Suggestion: Looking for a compatible outdoor "Light-bulb" Security Camera
A bonus would be if the camera can also respond to Home Assistant cURL shell_command commands to control Pan/Zoom/Tilt similar to the example below:ntegration. Whatever has the most detail pictures at night time or day time.
A bonus would be if the camera can also respond to Home Assistant cURL shell_command commands to control Pan/Zoom/Tilt like similar to the example below:
r/homeassistant - Suggestion: Looking for a compatible outdoor "Light-bulb" Security Camera
configuration.yaml
shell_command:
  cam_up: 'curl -k "http://192.168.1.67:3535/nphControlCamera?Direction=TiltUp&Resolution=1920x1080&Quality=Clarity&RPeriod=0&Size=STD&PresetOperation=Move&Language=0"'
  cam_down: 'curl -k "http://192.168.1.67:3535/nphControlCamera?Direction=TiltDown&Resolution=1920x1080&Quality=Clarity&RPeriod=0&Size=STD&PresetOperation=Move&Language=0"'
  cam_left: 'curl -k "http://192.168.1.67:3535/nphControlCamera?Direction=PanLeft&Resolution=1920x1080&Quality=Clarity&RPeriod=0&Size=STD&PresetOperation=Move&Language=0"'
  cam_right: 'curl -k "http://192.168.1.67:3535/nphControlCamera?Direction=PanRight&Resolution=1920x1080&Quality=Clarity&RPeriod=0&Size=STD&PresetOperation=Move&Language=0"'
  cam_home: 'curl -k "http://192.168.1.67:3535/nphControlCamera?Direction=HomePosition&Resolution=1920x1080&Quality=Clarity&RPeriod=0&Size=STD&PresetOperation=Move&Language=0"'
  cam_zoom_less: 'curl -k "http://192.168.1.67:3535/nphControlCamera?Direction=Preset&PresetOperation=Move&Data=4&Resolution=1920x1080&Quality=Clarity&RPeriod=0&Size=STD&Language=0"'
  cam_zoom_more: 'curl -k "http://192.168.1.67:3535/nphControlCamera?Direction=Preset&PresetOperation=Move&Data=5&Resolution=1920x1080&Quality=Clarity&RPeriod=0&Size=STD&Language=0"'
  cam_preset1: 'curl -k "http://192.168.1.67:3535/nphControlCamera?Direction=Preset1&PresetOperation=Move&Data=3&Resolution=1920x1080&Quality=Clarity&RPeriod=0&Size=STD&Language=0"'
  cam_preset2: 'curl -k "http://192.168.1.67:3535/nphControlCamera?Direction=Preset2&PresetOperation=Move&Data=3&Resolution=1920x1080&Quality=Clarity&RPeriod=0&Size=STD&Language=0"'
  cam_preset3: 'curl -k "http://192.168.1.67:3535/nphControlCamera?Direction=Preset3&PresetOperation=Move&Data=3&Resolution=1920x1080&Quality=Clarity&RPeriod=0&Size=STD&Language=0"'
I found this; however, I have no idea if it will do what I want. Maybe there is a better one? LaView 4MP Bulb Security Camera 5G& 2.4GHz WiFi, 360°2K Security Camera
