Hi
Could u please give some hint about the wemo link ? I’m having wemo led bulbs and a wemo bridge but I get the following errors during statup ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
6-05-19 08:39:15 homeassistant.bootstrap: Error during setup of component wemo Traceback (most recent call last): File “/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py”, line 157, in _setup_component if not component.setup(hass, config): File “/usr/local/lib/python3.4/dist-packages/homeassistant/components/wemo.py”, line 76, in setup devices = [(device.host, device) for device in pywemo.discover_devices()] File “/home/odroid/.homeassistant/deps/pywemo/discovery.py”, line 27, in discover_devices device = device_from_description(entry.location, mac) File “/home/odroid/.homeassistant/deps/pywemo/discovery.py”, line 39, in device_from_description return device_from_uuid_and_location(uuid, mac, description_url) File “/home/odroid/.homeassistant/deps/pywemo/discovery.py”, line 55, in device_from_uuid_and_location return Bridge(location, mac) File “/home/odroid/.homeassistant/deps/pywemo/ouimeaux_device/bridge.py”, line 39, in init self.bridge_update() File “/home/odroid/.homeassistant/deps/pywemo/ouimeaux_device/bridge.py”, line 49, in bridge_update endDeviceList = et.fromstring(endDevices.get(‘DeviceLists’)) File “/usr/lib/python3.4/xml/etree/ElementTree.py”, line 1326, in XML return parser.close() File “”, line None xml.etree.ElementTree.ParseError: syntax error: line 1, column 0 16-05-19 08:39:15 homeassistant.bootstrap: Unable to prepare setup for platform light.wemo because dependency wemo could not be initialized 16-05-19 08:39:48 homeassistant.bootstrap: Error during setup of component wemo Traceback (most recent call last): File “/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py”, line 157, in _setup_component if not component.setup(hass, config): File “/usr/local/lib/python3.4/dist-packages/homeassistant/components/wemo.py”, line 76, in setup devices = [(device.host, device) for device in pywemo.discover_devices()] File “/home/odroid/.homeassistant/deps/pywemo/discovery.py”, line 27, in discover_devices device = device_from_description(entry.location, mac) File “/home/odroid/.homeassistant/deps/pywemo/discovery.py”, line 39, in device_from_description return device_from_uuid_and_location(uuid, mac, description_url) File “/home/odroid/.homeassistant/deps/pywemo/discovery.py”, line 55, in device_from_uuid_and_location return Bridge(location, mac) File “/home/odroid/.homeassistant/deps/pywemo/ouimeaux_device/bridge.py”, line 39, in init self.bridge_update() File “/home/odroid/.homeassistant/deps/pywemo/ouimeaux_device/bridge.py”, line 49, in bridge_update endDeviceList = et.fromstring(endDevices.get(‘DeviceLists’)) File “/usr/lib/python3.4/xml/etree/ElementTree.py”, line 1326, in XML return parser.close() File “”, line None xml.etree.ElementTree.ParseError: syntax error: line 1, column 0 16-05-19 09:35:07 pychromecast.socket_client: Error communicating with socket, resetting connection
Thank you
