Hello guys! Need your help.
- Automation to turn on and off a switch
- Able to anticipate system downtime (power cut loss, crashes)
Any idea to merge it into single automation?
Hello Welcome to the community.
This is what I personally use- (suggestion made by Muttley here)
- platform: homeassistant
event: start
value_template: "{{ states('sensor.time') == '07:00' }}"
value_template: "{{ states('sensor.time') == '17:45' }}"
condition: []
- service: >-
{% if '07:00' <= states('sensor.time') < '17:45' %}
switch.turn_on
{% else %}
switch.turn_off
{% endif %}
entity_id:
- switch.light
Can you try to see if it works for you?
I dont seem to have sensor.time?
Sorry, I totally forget that you need to create the sensor first. So, sensor.time
can be created using Time & Date integration.
You will need to edit your configuration.yaml
by adding the following YAML code-
- platform: time_date
display_options:
- 'time'
You can do it without sensor.time
, though it is good to have.
event: start
- platform: time
at: '07:00'
- platform: time
at: '17:45'
- service: >
{% if '07:00' <= as_timestamp(now())|timestamp_custom('%H:%M') < '17:45' %}
switch.turn_on
{% else %}
switch.turn_off
{% endif %}
entity_id:
- switch.light
Or template-less
event: start
- platform: time
at: '07:00'
- platform: time
at: '17:45'
- choose:
- conditions:
- condition: time
after: '07:00'
before: '17:45'
sequence:
- service: switch.turn_on
entity_id: switch.light
default:
- service: switch.turn_off
mode: single
Haha template-less seems much easier to be understood.
Using your code, what will happen if at 17:30, suddenly power loss occurred and only comes back on at 20:00?
Seeing the action condition stated in your choose syntax, it is written (condition: time & after: ‘07:00’)- so after the system came back online, how can the automation choose the default ones? As 20:00 is also after 07:00?
Sorry if my question is confusing.
To follow the original automation you would have to add a before condition as well.
- choose:
- conditions:
- condition: time
after: '07:00'
before: '17:45'
sequence:
default:
So if it is inside that time window (7am to 5:45pm) the switch will turn on, otherwise off.
@tom_l Oeps One part of my brain was thinking two conditions and the other one plus a default… Time for a new cup of coffee!
@marcrogivue In that case the light will stay on till 20:00. Because on 20:00 the automation is triggered because of the HA start event. And then just checks the time and runs the turn off because it’s not between 7:00 and 17:45.
Thanks for clearing it up.
