Suggestions for troubleshooting RS485-Modbus sensor reporting "Unknown"
This is my first attempt to connect a RS485-Modbus sensor using ESPHome (8266+485 to serial UART. I had the two sensors I am playing around with (wind direction and wind speed) connected and working with ModScan32, so I know they are working. However, when connecting using the hardware listed above, in Home Assistant I get “Unknown.”
For the specifics (just trying with one sensor right now):
The settings that worked with ModScan32 were:
Device details:
Device is: 1
Device address: 0001
Length: 1
MODBUS Point Type: 03: HOLDING REGISTER
Connection details:
  • Baud rate: 4800
  • Word Length: 8
  • Parity: None
  • Stop bits: 1
The pertinent yaml code that I am using:
uart:
  tx_pin: GPIO01
  rx_pin: GPIO03
  baud_rate: 4800
  stop_bits: 1
modbus:
modbus_controller:
  address: 0x1
  modbus_id: modbus1
  - platform: modbus_controller
    modbus_controller_id: sensor1
    address: 1
    register_type: holding
    value_type: U_WORD
The error I get in the logs is:
modbus_controller:040]: Modbus command to device=1 register=0x01 countdown=0 no response received - removed from send queue
Appreciate any suggestions on what I should look at to help troubleshoot this. I don’t know where to start. If additional info is needed to help troubleshoot, please let me know.
Thanks!!
